Specifies a valid slot number. For devices
that do not support line cards, specify 0.
port
Specifies a valid port number.
ipip-address
Specifies a next-hop IP address.
veve-id
Specifies a virtual Ethernet (VE) interface.
no-refresh
Clears the ARP cache without resending ARP requests to the local hosts.
vrfvrf-name
Specifies a VRF instance.
Modes
Privileged EXEC mode
Usage Guidelines
If the
no-refresh keyword is not included, ARP requests are automatically triggered for the cleared entries. To avoid this triggering, include the
no-refresh keyword. It is required to include the
no-refresh keyword, in case the number of ARP entries reaches the system threshold
The following example clears all ARP entries on the device.
