The timeout parameters are not applied to the device.
Parameters
re-authperiodseconds
Specifies the interval at which clients connected to 802.1X authentication enabled ports are periodically reauthenticated. When periodic reauthentication is enabled using the
dot1x reauthentication command, the device reauthenticates the clients every 3,600 seconds by default. The
re-authperiod option allows you to specify the time interval between reauthentication attempts. The reauthentication interval configured using the
dot1x timeout re-authperiod command takes precedence.
supp-timeoutseconds
Specifies the EAP response timeout for 802.1x authentication. By default, when the device relays an EAP-Request frame from the RADIUS server to the client, it expects to receive a response from the client within 30 seconds. If the client does not respond within the allotted time, the device retransmits the EAP-Request frame to the client. The timeout value for retransmission of EAP-Request frames to the client can be configured using the
supp-timeoutseconds parameters.
tx-periodseconds
Specifies the EAP request retransmission interval, in seconds, with the client. By default, if the device does not receive an EAP-response/identity frame from a client, the device waits 30 seconds, then retransmits the EAP-request/identity frame. You can optionally change the amount of time the device waits before re-transmitting the EAP-request/identity frame to the client. If the client does not send back an EAP-response/identity frame within 60 seconds, the device will transmit another EAP-request/identity frame. The tx-period is a value from 1 through 4294967295. The default is 30 seconds.
Modes
Interface configuration mode
Usage Guidelines
The
no form of the command disables dot1x timeout.
The following example sets 25 seconds as the amount of time between reauthorization attempts on a specific interface.
The following example sets 34 seconds as the waiting period for a response to an EAP-request or identity frame from the client before retransmitting the request on a specific interface.
