Applies rules specified in an IPv4 access control list (ACL) to traffic entering or
exiting an interface.
Syntax
ip access-groupACLname{in[ routed ]|out}no ip access-groupACLname{in|out}
Parameters
ACLname
Specifies the name of the standard or extended IPv4 access list.
in
Applies the ACL to incoming switched and routed traffic.
out
Applies the ACL to outgoing routed and (for SLX 9150 and SLX 9250 devices) also to switched traffic.
routed
Optional Parameter. Applies only to an
ingress ACL. This parameter is only supported when ACL is applied to inbound
traffic on a Layer 3 sub-interface such as the VE interface.
Modes
Interface subtype configuration mode
Usage Guidelines
Use this command to apply an IPv4 ACL to one of the following interface types:
User interfaces
Physical Ethernet interfaces
Port-channels (LAGs).
Virtual Ethernet (VE) (attached to a VLAN or to a bridge domain)
The management interface
You can apply a maximum of five ACLs to a user interface, as follows:
One ingress MAC ACL—if the interface is in switchport mode
One egress MAC ACL—if the interface is in switchport mode
One ingress IPv4 ACL
One egress IPv4 ACL
One ingress IPv6 ACL
You can apply a maximum of two ACLs to the management interface, as follows:
You can apply an ACL to multiple interfaces. And you can apply an ACL twice—ingress
and egress—to a given user interface.
To remove an ACL from an interface, enter the no form of this
command.
The routed parameter can only be applied for ingress ACLs
applied to a VE interface. This option is not available on other interfaces.
You cannot modify an existing ingress ACL definition to include the
routed parameter. An error is displayed.
The no format of the command cannot be used to remove the
routed parameter from the ACL. You must delete the entire ACL
configuration and re-configure to change the ACL.
The following example applies an ingress IP ACL on an Ethernet interface:
SLX (config)# interface ethernet 0/2
SLX (conf-if-eth-0/9)# ip access-group ipacl2 in
The following example removes an ingress IP ACL from an Ethernet interface:
SLX (conf-if-eth-0/9)# no ip access-group ipacl2 in
This example shows the configuration of the
routed parameter on an ingress ACL on a VE.
SLX (config)# interface ve 10
SLX (config-if-ve-10)# ip access-group ipacl2 in routed
SLX (config-if-ve-10)# do show run interface ve 10
interface Ve 10
