ip routedest-ip-addr[next-hop-vrfnext-vrf-name]next-hop-address[metric][distancedistance][tagtag-number][namename-value]ip routedest-ip-addr{ethernetslot/port|port-channelnumber|veve-number} [metric][distancedistance][tagtag-number][namename-value]ip routedest-ip-addrnull 0[metric][distancedistance][tagtag-number][namename-value]ip routenext-hop-recursionno ip routedest-ip-addr[next-hop-vrfnext-vrf-name]next-hop-addressno ip routedest-ip-addr{ethernetslot/port|veve-number} no ip routedest-ip-addrnull 0no ip routenext-hop-recursion
Parameters
next-hop-vrfvrf-name
Specifies the name of the non-default VRF to be used for as the next-hop gateway.
dest-ip-addr
Specifies the destination IPv4 address and mask in the format A.B.C.D/L (where "L" is
the prefix length of the mask).
next-hop-addr
Specifies the IPv4 address of the next hop.
ethernetslot/port
Specifies the destination Ethernet port.
VRF name of the next hop.
port-channelnumber
Specifies a port-channel interface.
vevlan-id
Specifies the outgoing interface type as VE.
null 0
Configures the Layer 3 switch to drop IP packets to a specific network or host address
by configuring a "null" (sometimes called "null0") static route for the address.
metric
Specifies the cost metric of the route. Valid values range from 1 through 16. The
default is 1.
distancedistance
Specifies the administrative distance of the route. When comparing otherwise equal
routes to a destination, an SLX-OS device prefers lower
administrative distances over higher ones. Valid values range from 1 through 254. The
default is 1.
tagtag-number
Specifies the tag value of the route to use for route filtering with a route map.
Valid values range from 0 through 4294967295. The default is 0.
next-hop-recursion
Specifies that if the next hop for a static route is reachable, then that route is
added to the routing table.
namename-value
Specifies the name to be assigned to this IP route. This field can be used to assign a
meaningful, human readable description to this route configuration. Maximum length 127
characters.
Modes
Global configuration mode
VRF configuration mode
Usage Guidelines
The no form of the command followed by the route identifier removes a
static route.
If you do not want to specify a next-hop IP address, you can instead specify a physical or
virtual interface on the SLX-OS device. If you specify an Ethernet
port, the device forwards packets destined for the static route‘s destination network to the
specified interface. Conceptually, this feature makes the destination network like a
directly connected network, associated with an SLX-OS device
interface.
The port or virtual interface you use for the static route‘s next hop must have at least
one IP address configured on it. The address does not need to be in the same subnet as the
destination network.
For a default route, use the following as the destination IP address 0.0.0.0/0.
You can create a null route for traffic for traffic that should not be forwarded. To create
a null route, use the key phrase null 0 as the next hop.
The following example configures a static route to 10.95.7.0 addresses, using
10.95.6.157 as the next-hop gateway.
device(config)# ip route 10.95.7.0/24 10.95.6.157
The following example configures a default route to next-hop IP address 10.24.4.1.
device(config)# ip route 0.0.0.0/0 10.24.4.1
The following example configures a static route with an Ethernet interface as the
destination, and assigns a name to it.
device(config)# ip route 192.128.2.69/24 ethernet 4/1 name route-sj-01
The following example configures a null static route to drop packets destined for network
10.157.22.x.
device(config)# ip route 10.157.22.0/24 null 0
The following example configures non-recursive lookup in the default VRF.
device(config)# ip route next-hop-recursion
The following example configures non-recursive lookup in a non-default VRF named red.
device(config)# vrf red
device(config-vrf-red)# address-family ipv4 unicast
device(config-vrf-red-ipv4-unicast)# ip route next-hop-recursion
