Configures the virtual connection (VC) mode for a pseudowire (PW) profile.
Syntax
vc-mode{raw|raw-passthrough|tag}no vc-mode
Command Default
The default VC mode is
raw.
Parameters
raw
Specifies using raw mode. At VC label
imposition, when a tagged packet is received on a tagged AC endpoint, the
VLAN tag is removed before it is sent out on the wire. Untagged packets that
are received on an untagged AC endpoint are encapsulated as is and sent out
on the wire.
raw-passthrough
(is supported on the Extreme 8820, SLX 9740, SLX 9640, and SLX 9540 devices only.) Specifies using
raw-passthrough mode, which enables interoperation with third-party devices.
When all endpoints are configured as tagged endpoints, raw passthrough mode
behaves the same way as tagged mode. When all endpoints are configured as
untagged endpoints, raw-passthrough mode behaves the same way as raw mode.
Select the raw-passthrough option, when all endpoints are
configured as untagged endpoints (even when peer devices signal the PW VC
mode as raw).
tag
The tag option is not supported on the SLX 9640 platform.
Specifies using tag
mode. At VC label imposition, when a tagged packet is received on a tagged
AC endpoint, the packet is encapsulated as is and sent out on the wire. When
an untagged packet is received on an untagged AC endpoint, a dummy tag is
added and it is sent out on the wire.
Modes
Pseudowire-profile configuration mode.
Usage Guidelines
The no form of the command
restores the default value.
The raw-passthrough
parameter is supported on the Extreme 8820, SLX 9740, SLX 9640, and SLX 9540 devices only.
The following example shows how to
set the VC mode to raw-passthrough for a PW profile named test.
device# configure terminal
device(config)# pw-profile test
device(config-pw-profile-test)# vc-mode raw-passthrough
The following example shows how to set the VC mode to tag for a PW profile named test.
device(config-pw-profile-test)# vc-mode tag
