Specifies the IPv4 or IPv6 address of the NTP
peer.
keykey_id
Specifies the symmetric key
ID. By default, no symmetric key is configured. The range is 1 to 65,534.
maxpollinterval
Specifies the longest polling
interval. The range is 4 to 17. Default is 10. The interval argument is
power of 2, for example: 3=8s, 4=16s, 5=32s, 6=64s, 7=128s, 8=256s, 9=512s.
minpollinterval
Specifies the shortest
polling interval. The range is 4 to 17. The default is 6. The interval
argument is power of 2, for example: 3=8s, 4=16s, 5=32s, 6=64s, 7=128s,
8=256s, 9=512s.
use-vrfvrf_name
Specifies the VRF name to synchronize the
time with server. The default is mgmt-vrf.
version3 | 4
Specifies the NTP version supported by the
peer. The default is 4.
Modes
Global configuration mode
Usage Guidelines
This command is not effective if the NTP is enabled in client-only mode. If the peer
is already mobilized as symmetric passive, then configuring statically will not be
effective.
The no form of the command
removes the peer configuration and applied options.
Configures the NTP peers and
specify the peers to synchronize the system clock.
The following error message is displayed when the minimum poll value is greater
than maximum poll value: Minimum poll interval cannot be greater than
maximum poll interval.
