shutdown Physically disable out-of-band access to the BMC Management Interfaces. This prevents access to the interface from outside. Only BMC Management Interface 0 is supported.
shutdown (LIF) Removes a physical or port-channel interface on an edge port from participating in logical interface (LIF) data traffic without the need to shut down the interface.
shutdown-time Specifies a shutdown time to ensure convergence when maintenance mode is enabled on a SLX-OS device.
site Creates a remote Layer 2 extension site in a VXLAN overlay gateway context and accesses site configuration mode.
snmp-server community Sets the community string and associates it with the user-defined group name to restrict the access of MIB for SNMPv1 and SNMPv2c requests.
snmp-server sys-descr Sets the Management Information Base (MIB-2) object identifier (OID) system description.
snmp-server trap Switches between standard and enterprise MIB to generate the BFD traps. When this CLI is configured, the BFD traps defined in standard MIB get generated.
snmp-server use-vrf Configures SNMP Listening Service on a VRF. SNMP listening service over mgmt-vrf and default-vrf will be enabled by default. Also the Listening service enable/disable related CLI is applicable for SNMP Get related operations and it will not impact notification operations.
snmp-server user Creates or changes the attributes of SNMPv3 users, and allows the SNMPv3 user to be associated with the user-defined group name.
snmp-server v3host Specifies the host recipient for SNMPv3 trap notification.
snmp-server view Creates a view entry with MIB object IDs to be included or excluded for user access.
soft-preemption The soft-preemption command enables soft preemption functionality. This command must be used on both the primary and secondary paths.
soft-preemption cleanup-timer Sets the amount of time that the point of preemption must wait to receive the path tear notification from the ingress LSR before sending a hard preemption path error.
source Configures the source address or a source interface for a tunnel interface.
spanning-tree edgeport Enables the edge port on an interface to allow the interface to quickly transition to the forwarding state.
spanning-tree guard root Enables the guard root to restrict which interface is allowed to be the spanning tree root port or the device's path-to-the-root.
spanning-tree link-type Enables and disables the rapid transition for the Spanning Tree Protocol (STP).
spanning-tree portfast Enables the Port Fast feature on an interface to allow the interface to quickly transition to forwarding state.
ssh client key-exchange Specifies the method used for generating the one-time session keys for encryption and authentication with the Secure Shell (SSH) server and Diffie-Hellman group 14.
ssh client mac Supports MAC configurations for the SSH client.
ssh server algorithm Configures the SSH server host key algorithm to be used for X.509v3 certificate-based SSH authentication (server authentication).
ssh server certificate Configures the SSH server certificate profile and enters SSH server certificate profile configuration mode.
ssh server cipher Sets the SSH server's cipher list for the SSH server.
ssh server key Generates or zeroizes SSH crypto keys on the device. All three keys can be active simultaneously.
ssh server key-exchange Specifies the method used for generating the one-time session keys for encryption and authentication with the Secure Shell (SSH) server and Diffie-Hellman group 14.
ssh server mac Supports MAC configurations for the SSH server.
ssh server max-auth-tries Configures the maximum number of times a user is allowed to try to authenticate to the SSH server.
ssh server max-idle-timeout Configures the maximum number of seconds that the SSH session is allowed to idle before timing out.
ssl-profile Use the ssl-profile command to configure the lowest TLS version supported by the SLX software. SLX uses OpenSSL to provide transport layer security and the current version of OpenSSL supports TLS v 1.1 to TLS v 1.2. Since the SLX box can be considered as both a client as well as a server, you can apply different supported TLS versions for each of these types. This ssl-profile command enables you to select the SLX operation mode from either Client or Server and then set the lowest supported TLS version.
ssm-enable Enables Source Specific Multicast (SSM) mode for IPv4 PIM.
start (CFM) Defines the start time for a delay measurement receiver session.
suppress-arp Enables Address Resolution Protocol (ARP) suppression on a current VLAN or bridge domain. ARP suppression can lessen ARP-related traffic within an IP Fabric.
suppress-nd Enables Neighbor Discovery (ND) suppression on a VLAN or bridge domain. ND suppression can lessen the amount of ND control traffic within an IP Fabric.
switch-attributes Configures the chassis or host name for the device.
switchport Puts the interface in Layer 2 mode and sets the switching characteristics of the Layer 2 interface.
switchport port-security sticky Enables sticky MAC learning on the port to convert the dynamically learned MAC addresses to sticky secure MAC addresses.
switchport trunk native-vlan-untagged Configures a port to accept only untagged packets, and specifies that those packets be egress untagged. The untagged packets may be classified to an 802.1Q VLAN, a service VF, or a transport VF.
system-monitor tm Accesses system monitor traffic manager (sys-mon TM) configuration mode to configure the monitoring of the traffic manager (TM) device or Virtual Output Queue (VOQ) discarded packets.
system-monitor-mail Configures various email settings as part of system monitoring.
threshold-monitor acl Configures monitoring the utilization of finite user configurable ACL resources like MAC ACL, IP ACL, and IPv6 ACL. The current values of ternary content-addressable memory (TCAM) occupied by these ACLs are compared against the available hardware resources in a configured hardware profile. An alarm is raised every time the consumed resources crosses the configured high threshold level indicating a high utilization and also when, the utilization, subsequently, falls below the configured low threshold limit, indicating that the utilization has reached safer levels. The alarm for low threshold is generated only in the case that an alarm for crossing the high threshold is already generated.
threshold-monitor Cpu Configures monitoring of CPU usage of the system and alerts the user when configured thresholds are exceeded.
threshold-monitor memory Configures monitoring of the memory usage of the system and alerts the user when configured thresholds are exceeded.
threshold-monitor bfd-sessions Configures monitoring of the number of BFD Session against the maximum number of supported BFD sessions and alerts the user when configured thresholds are exceeded.
threshold-monitor ecmp Configures monitoring the utilization of the ECMP Table. The current values of number of ECMP Next Hop entries (in %) is compared with the configured profile limits and against the available hardware space. An alarm is raised when the number of entries falls below the configured low threshold or exceeds the configured high threshold.
threshold-monitor hardware-resources Configures the maximum number of events to be generated in a configured time period for any hardware events on the device.
threshold-monitor host Configures monitoring of the utilization of the Host Table. The current values of number of host entries (in %) (both IPv4 ARP entries and IPv6 Neighbor entries) are compared with the configured profile limits and against the available hardware space. An alarm is raised when the number of entries falls below the configured low threshold or exceeds the configured high threshold.
threshold-monitor lif Configures monitoring of the number of LIFs against the maximum number of supported LIFs and alerts the user when configured thresholds are exceeded.
threshold-monitor mac-table Configures monitoring of the utilization of available MAC Table resources and alerts the user when configured thresholds are exceeded.
threshold-monitor nexthop Configures the monitoring the utilization of the Next Hop Table or the Encap Table depending on the platform. The current values of number of next hop entries (in %) is compared with the configured profile limits and against the available hardware space. An alarm is raised when the number of next hop entries falls below the configured low threshold or exceeds the configured high threshold.
threshold-monitor route Configures monitoring the utilization of the Route Table. The current values of number of routes (in %) (both IPv4 and IPv6 routes) are compared with the configured profile limits and against the available hardware space. An alarm is raised when the number of routes falls below the configured low threshold or exceeds the configured high threshold.
threshold-monitor vxlan-tunnel Configures monitoring of the number of VXLAN Tunnels against the maximum number of supported VXLAN tunnels and alerts the user when configured thresholds are exceeded.
threshold-timer (management-heartbeat) Configures the threshold value for listening to heartbeat message from EFA. Used within the management-heartbeat context.
tie-breaking Configures the device to choose the path with the highest available bandwidth or the lowest available bandwidth.
timeout (link-oam) Allows you to configure timeout value, which corresponds to hold time before the Discovery process restarts.
timeout (RADIUS) Species the wait time allowed for a Remote Authentication Dial-In User Service (RADIUS) server response.
timer Sets the global MVRP join, leave and leave-all timers values on all MVRP-enabled interfaces except the interfaces configured with the mvrp timer command in interface configuration mode.
timers (BGP) Adjusts the interval at which BGP KEEPALIVE and HOLDTIME messages are sent.
timers (OSPFv2) Configures Link State Advertisement (LSA) pacing and Shortest Path First (SPF) throttle timers.
timers (OSPFv3) Configures Link State Advertisement (LSA) pacing and Shortest Path First (SPF) timers.
tls min-version The command enables configuring the lowest TLS version supported by SLX OS for the Client and Server modes of operation of the SLX device. This command is available under the respective modes under the Management Security SSL Profile mode. SLX uses OpenSSL to provide transport layer security and the current version of OpenSSL supports TLS v 1.1 to TLS v 1.3. Since the SLX box can be considered as both a client as well as a server, you can apply different supported TLS versions for each of these types. The default TLS version supported is v 1.2.
tlv-type Enables the Port Status type-length-value (TLV) metric for the specified Maintenance End Points (MEP).
to Configures a destination address for the bypass LSP.
tpvm config ldap Configures an LDAP server in a Third-Party VM (TPVM).
tpvm config ldap ca-cert Imports or removes certificates for LDAP over TLS in a Third-Party VM (TPVM).
tpvm config ntp Configures the Network Time Protocol (NTP) for a Third-Party VM (TPVM) and now gets/display IPv6 configurations with IPv4 configurations.
tpvm config trusted-peer Adds and removes bi-directional password-less SSH connection between the root user accounts of both the TPVM and Peer TPVM instances.
tpvm deploy Performs TPVM and Insight Interface set up and configuration.
tpvm download Downloads the TPVM image from the remote location, and then optionally, verifies if the file size and the version of the downloaded TPVM image is correct.
tpvm fileinfo Displays information for the TPVM image file stored in the /tftpboot/SWD2900 directory of the SLX-OS. TPVM is installed from this image file.
tpvm (mode) Enters into the TPVM persistence configuration mode. Only one TPVM instance can be configured at present. Currently, the tpvm-id only allowed value is TPVM, and its optional and default also.
ldap host Configures an LDAP server in the TPVM instance.
ldap ca-cert Imports or removes certificates for LDAP over TLS in the TPVM instance.
ntp (tpvm mode) Configures the Network Time Protocol (NTP) server for TPVM instance. Supports IPv4 and IPv6 addresses.
tpvm dns Configures the DNS server details for the TPVM instance. DNS configuration CLI already supports IPv4 address. It is enhanced to support IPv6 address.
trusted-peer (tpvm mode) Adds and removes bi-directional password-less SSH connection between the root user accounts of both the TPVM and Peer TPVM instances.
disk (tpvm mode) Adds disks to TPVM. Up to three (3) disks can be added. These disks can be added only in the order vdb, vdc, and vdd. When removing disks, they must be removed in the order vdd, vdc, and vdb (in the reverse order in which they were added). When the auto parameter is used, the name of the next disk in the order will be selected and added to the TPVM configuration.
password (tpvm mode) Updates the password for the default TPVM user account extreme. The password can be normal text string or encrypted string.
deploy (tpvm mode) This configuration will deploy the TPVM instance. It performs multiple steps of installing and starting the TPVM, as well applying all TPVM instance related configuration, which is currently set in the SLX configuration database. The no deploy configuration will purge the TPVM instance, which implies stop, uninstall and delete, as well as applying all TPVM instance related configurations in the SLX config database. This is similar to no tpvm TPVM.
tpvm upgrade Upgrades the TPVM image. This command downloads the TPVM Debian image file using SCP or SFTP or FTP servers. Any previously installed TPVM instance is upgraded, and TPVM configuration from the SLX configuration database is applied, if available. Upgrades can be full or incremental. By default, full upgrades are performed.
tpvm snapshot Manually creates and manages TPVM snapshots. These snapshots can then be used to restore a TPVM to its previous state post any TPVM crash.
traceroute Traces the network path of packets as they are forwarded to a destination address.
track (VRRP) Enables VRRP tracking for a specified interface. VRRP Extended (VRRP-E) sessions can track a specified interface or a network.
traffic-engineering (LSP) Allocating bandwidth to an LSP lets the LSRs determine how much bandwidth the LSP can consume and how much of the available bandwidth resources can be advertised.
traffic-engineering (MPLS) When an MPLS-enabled device receives an IS-IS TE LSP, it stores the traffic engineering information in its Traffic Engineering database (TED). The device uses information in the TED when performing calculations to determine a path for an LSP. The user can configure the device to send out IS-IS TE LSPs for all of its MPLS-enabled interfaces.
transport Specifies the transport protocol for network-elements telemetry streaming.
trigger Defines event-handler triggers. When the trigger-condition occurs, a Python script is run.
trigger-function Specifies whether the action runs only if all of the triggers occur or if one is sufficient, for an implementation of an event-handler profile when multiple triggers are defined for an event-handler action.
trigger-mode For an implementation of an event-handler profile, specifies if recurring trigger conditions can launch an event-handler action more than once.
trustpoint sign Configures the trustpoint to the server certificate profile that is used to sign the server certificate.
ttl Configures the time to live (TTL) value for a tunnel interface.
tunable-optics This command assigns channels to tunable optic interfaces (T-SFP+) for specific wavelengths.
tunneled-arp-trap enable Enables ARP (Address Resolution Protocol) packets that come through a tunnel to be trapped to CPU.
