The server IP address in either IPv4 or IPv6 format.
port-numberport
Specifies the port number in the remote device to connect to. Range is from 0 through 65535. For the connection to succeed, a TCP server must be listening for client connections at the specified port.
vrfvrf-name
Specifies a VRF instance. See the Usage Guidelines.
hostname
Specifies the host name which is a string between 1 and 63 ASCII characters in length.
port-numberport
interface
Specifies an interface.
ethernetslot/port
Specified the Ethernet interface slot and port number.
management
Specifies the management interface.
veVE-id
Specifies the VE interface number.
Modes
Privileged EXEC mode
Usage Guidelines
You can override the default port. However, the device must be listening on this port for the connection to succeed.
The following features are not supported:
Display Telnet sessions
Ability to terminate hung Telnet sessions
The following example establishes a Telnet connection to a remote device.
