Downloads the TPVM image from the remote location, and then optionally, verifies if the file size and the
version of the downloaded TPVM image is correct.
Optional Parameter. When passed, it enables NetCONF/RPC requests to
operate in the blocking mode. When not passed, NetCONF/RPC operation is always
non-blocking. This parameter does not affect CLI commands as CLI is always considered
blocking in nature.
directoryremote-directory-name
Specifies the remote directory that contains the TPVM image.
filenameimage-file-name
Specifies the TPVM Debian image file name.
host [hostname|ip-address]
Specifies the remote server. Remote server information can be provided either as a
hostname or ip-address. Both IPv4 and IPv6 addresses are
supported.
password password
Password for the username
provide in the user parameter.
protocol{FTP|SCP|SFTP}
Specifies the use of either
FTP, SCP or SFTP protocol for exporting the certification file.
sanity [yes|no]
Optional parameter. When set to yes, the TPVM image file is verified for
size and version number after being downloaded. When set to no, the TPVM
image is downloaded but not verified.
use-vrf vrf-name
Defines the VRF to use to access the remote host.
user user-name
The account that will be used to access the remote host. The password of this account
is passed in the password parameter.
Modes
Privileged EXEC mode
Usage Guidelines
Use the optional sanity key to ensure that the downloaded TPVM image is
verified for version and length after it has been downloaded from the remote server.
Use the optional block key to indicate that NetCONF/RPC calls are
considered blocking in nature. By default, NetCONF/RPC calls are
non-blocking. Also, CLI commands are always blocking by nature. This
key does not affect this action when performed through SLX-OS CLI.
The following example shows the usage of the tpvm
download command. This example shows the interactive mode for this command.
SLX # tpvm download ?
Possible completions:
block optional wait mode for netconf
directory Remote directory
filename TPVM debian filename
host Hostname or IPv4/IPv6 address
password Password for the user
protocol Protocol
sanity Perform sanity check
use-vrf Vrf to use for downloading TPVM package (Default =mgmt-vrf)
user Login name in the host
SLX# tpvm download sanity ?
<yes|no> Sanity check
