capability as4-enable Enables 4-byte autonomous system number (ASN) capability at the BGP global level.
ccm-interval Sets the time interval between two successive Continuity Check Messages (CCMs) that are sent by Maintenance End Points (MEP) in the specified Maintenance Association (MA).
cee-map Converged Enhanced Ethernet (CEE) enables you to configure the ETS/CEE parameters including mapping of incoming priorities (traffic with different CoS) to traffic-classes, assigning weights and corresponding bandwidths to those priorities, and scheduling of all occupied traffic-class traffic to egress wire.
certutil import sshkey Imports an SSH public key for a local SSH user from a remote host using the login credentials and path name.
certutil sshkey Enters an SSH public key for a specific user by using the command line interface (CLI).
certutil sshx509v3 Configures the SSH user certificate Distinguished Name (DN).
cfm linktrace Transmits a linktrace message to a Maintenance End Point (MEP) in the domain
cfm loopback Transmits a loopback message to a specific Maintenance End Point (MEP) or Maintenance Intermediate Point (MIP) in a specified domain.
cfm y1731 domain Sets the on-demand two-way delay measurement or two-way synthetic loss measurement parameters.
channel-group Enables link aggregation on an interface.
chassis Sets the IPv4 or IPv6 address of a device.
cipherset Configures FIPS-compliant ciphers for the Lightweight Directory Access Protocol (LDAP).
cisco-interoperability Configures the device to interoperate with some legacy Cisco switches.
class Creates a class map in a policy map and enters the class map configuration mode.
class-map Enters class (classification) map configuration mode.
clear arp Clears some or all Address Resolution Protocol (ARP) entries.
clear ip arp suppression-cache Clears the IPv4 ARP-suppression cache and downloads the current forwarding database from BGP-EVPN. You can also clear the cache for a specified bridge domain or VLAN.
clear ip bgp neighbor Requests a dynamic refresh of BGP4 connections or routes from a neighbor, with a variety of options.
clear ip bgp neighbor dynamic Clears all dynamic neighbor connections on a device, in a specified VRF, or in a VPNv4 or VPNv5 address family.
clear ip bgp routes Clears BGP4 routes from the IP route table and resets the routes.
clear ip bgp rpki server Use this command to stop and restart the RTR library configuration for this particular RPKI server. This command closes the current session and tries to re-establishes connection with the configured RPKI server. The all format of this command closes all sessions and tries to re-establish connections.
clear ip igmp groups Removes the accumulated information about learned groups for a specified VLAN, bridge domain, MCT (Multi-Chassis Trunking) cluster, or CCEP (Cluster Client Edge Port) client.
clear ip igmp statistics Removes the accumulated IGMP statistics on the specified VLAN or bridge domain.
clear ip multicast snooping mcache Removes the accumulated information about the multicast forwarding cache for a VLAN or a bridge domain.
clear ipv6 mld groups Removes the accumulated information about learned groups for a specified bridge domain, VLAN, MCT (Multi-Chassis Trunking) cluster, or CCEP (Cluster Client Edge Port) client.
clear ipv6 mld snooping Clears the IPv6 multicast snooping database, including entries for MLD snooping and IPv6 PIM snooping, for a VLAN or a bridge domain.
clear ipv6 mld statistics Removes the accumulated MLD statistics on the specified VLAN or bridge domain.
clear ipv6 nd suppression-cache Clears the neighbor discovery (ND)-suppression cache. You can also clear the cache for a specified bridge domain or VLAN.
clear ipv6 nd suppression-statistics Clears suppression statistics for neighbor discovery. You can also clear statistics for a bridge domain or VLAN.
clear loop-detection Enables ports that were disabled by the loop detection (LD) protocol, and clears LD statistics at the global, interface, or VLAN level.
clear loop-detection bridge-domain Enables ports associated with the bridge domain (BD) that were disabled as part of loop detection, and also clears the LD statistics per BD.
clear mpls lsp Allows the user to reset normal LSPs. The user has the option of supplying the primary or secondary parameter for a normal LSP to reset only the primary or secondary path of the LSP.
CLI In a Python shell, runs a device CLI command or series of commands. You can also assign the output of such commands to a Python object.
client Configures a Multi-Chassis Trunking (MCT) client for a cluster and access cluster client configuration mode.
client-interface Configures a CEP or CCEP interface to the cluster client instance.
client-interface (Y1731) Associates either a physical interface or a port-channel interface to a Y1731 Maintenance Entity Group End Point (MEP) as a client interface.
client-interfaces-shutdown Disables the local client interfaces administratively in the cluster to move all traffic on the device to a remote MCT peer device, resulting in failover of traffic to the peer device.
client-pw Configures the pseudowire (PW) client for an MCT cluster used with VPLS or VLL and access cluster client PW configuration mode.
client-to-client-reflection Enables routes from one Route Reflector (RR) client to be reflected to other clients by the host device on which it is configured.
clock timezone Sets the device system clock time zone options using either Greenwich Mean time (GMT) or one of the US time zones that uses Universal Time Coordinated (UTC) plus or minus a number of hours.
cluster Configures a Multi-Chassis Trunking (MCT) cluster and access the cluster configuration mode.
cluster-client auto Configures a Multi-Chassis Trunking (MCT) client for a cluster in auto mode.
cluster-track Configures interface to track state of MCT cluster.
commit Use the commit command to commit modifications done to adaptive parameters of a bypass LSP. This command also applies to LSPs. This is not a configuration persistent command; it is a functional command.
compare-med-empty-aspath Enables comparison of Multi-Exit Discriminators (MEDs) for internal routes that originate within the local autonomous system (AS) or confederation
compare-routerid Enables comparison of device IDs, so that the path-comparison algorithm compares the device IDs of neighbors that sent otherwise equal-length paths.
core-isolation-disable Core Isolation feature shuts down ESI interface(s) when all the core interfaces between the Leaf and Spine nodes go down. This feature is enabled by default. Use this command to disable this feature. When disabled, the ESI interface will not be brought down when all the core interfaces between the Leaf and Spine go down.
core-isolation-track Core Isolation feature shuts down ESI interface(s) when all the core interfaces between the Leaf and Spine nodes go down. During core-isolation, data traffic will be black-holed in the multi-homing nodes if the single homed edge port interfaces are present and the Ethernet VPN Instance VLANs are shared with these interfaces. These single homed edge port interfaces need to be brought up/down along with the ESI client interfaces for better data convergence. This command enables tracking these single homed edge port interfaces to ensure that they are brought up/down along with ESI client interfaces.
cos (MPLS) Configures the a Class of Service (CoS) priority value for all packets traveling through the LSP.
convergence-time Configures the convergence time when transitioning out of Maintenance Mode. Convergence time comes into play only when Maintenance Mode is disabled.
crypto ca authenticate Identifies the root CA certificate, which is used to sign the Certificate Signing Request (CSR) to generate the server certificate.
crypto ca enroll Enrolls the trustpoint by generating the Certificate Signing Request (CSR) and exporting it to the remote certificate server.
crypto ca import Imports the Identity Certificate for security configuration.
crypto cert expiry-level Configures generating notifications for certificate expiry. Depending on the number of days to certificate expiry, notifications with different warnings are generated. Notifications can be RASLog or SNMP or both.
crypto import Imports the Identity Certificate for security configuration.
crypto key Generates an RSA, ECDSA, or DSA key pair to sign or encrypt and decrypt the security payload during security protocol exchanges for applications. You must sign and encrypt or decrypt the key pair before you obtain a certificate for your device.
csnp-interval Configures the Complete Sequence Number PDU (CSNP) interval.
cspf-computation-mode The path calculation metric implementation allows you to specify the path calculation for a given tunnel.
cspf-interface-constraint Forces the CSPF calculation to include any specified interface when creating an LSP.
cspf-group Configures a CSPF fate-sharing group by assigning a name to the group.
cspf-group-computation Use the cspf-group-computation mode when setting up a fate-sharing group.
dampening Sets dampening parameters for the route in BGP address-family mode.
default-ipv6-gateway Configures the IPv6 address of the default gateway on a VLAN.
default-link-metric Configures the metric value globally on all active Intermediate System-to-Intermediate System (IS-IS) interfaces for a specified address family.
default-local-preference Enables setting of a local preference value to indicate a degree of preference for a route relative to that of other routes.
delay For an implementation of an event-handler profile, specifies a delay from when a trigger is received until execution of the event-handler action.
delay-link-event Configures the port transition hold timer to set a delay in the sending of port up or down port events, or both, to Layer 2 protocols.
delete Deletes a user-generated file from the flash memory.
delete-packet Configures the logging or monitoring interval for all Traffic Management (TM) deleted packets on the SLX-OS device.
destination Configures the destination address for the tunnel interface.
dhcp ztp cancel The Zero Touch Provisioning (ZTP) session indefinitely retries detecting the DHCP server to establish a network connection for firmware download. Once canceled, the ZTP session stops retrying.
dhcp ztp log Displays the Zero Touch Provisioning progress log.
dir Lists the contents of the device flash memory.
disable-adjacency-check Disables Intermediate System-to-Intermediate System (IS-IS) IPv6 protocol-support consistency checks that are performed prior to forming adjacencies on hello packets.
disable-incremental-spf-opt Disables incremental full SPF optimizations for Intermediate System-to-Intermediate System (IS-IS).
disable-partial-spf-opt Disables partial SPF optimizations for Intermediate System-to-Intermediate System (IS-IS).
disallow-oar-ac Allows multiple attachment circurit (AC) endpoints on a virtual router interface that is configured for a VPLS instance.
discard-packet Configures the logging or monitoring interval for all Traffic Management (TM) discarded packets on the SLX-OS device.
discard-voq-packet Configures the logging interval or threshold for all Virtual Output Queue (VOQ) discarded packets.
distance (BGP) Changes the default administrative distances for eBGP, iBGP, and local BGP.
distance (IS-IS) Configures an administrative distance value for Intermediate System-to-Intermediate System (IS-IS) routes.
distance (OSPF) Configures an administrative distance value for OSPFv2 and OSPFv3 routes.
distribute Enables advertisement of Border Gateway Protocol flow specification (BGP flowspec) rules that are configured under a route map.
distribute-list prefix-list (OSPFv3) Applies a prefix list to OSPF for IPv6 routing updates. Only routes permitted by the prefix-list can go into the routing table.
domain-name Creates a maintenance domain at a specified level and name and enters the maintenance domain mode specified in the command argument.
dot1ag-compliance Enables IEEE 802.1ag (Dot1ag) compliance configuration mode to configure left and right interfaces, by associating MD name, MA name, MEP ID, and RMEP ID per interface for both ERP left and right interfaces for signal failure and recovery. This allows MDs, MAs, and MEPs to be configured as part of Dot1ag and to be associated with an Ethernet Ring Protection (ERP) instance to achieve faster convergence.
dot1x filter-strict-security Enables or disables strict filter security for dot1x authentication on the interface.
dot1x max-req Configures the retransmission parameter that defines the maximum number of times EAP request/challenge frames are retransmitted when EAP response/identity frame is not received from the client.
dot1x port-control Controls port-state authorization and configures the port control type to activate authentication on an 802.1X-enabled interface.
dot1x quiet-period Configures the time interval that the device remains idle between a failed authentication and a reauthentication attempt.
dot1x reauthenticate Initiates 802.1X reauthentication on a specified interface.
dot1x reauthentication Configures the device to periodically reauthenticate the clients connected to 802.1X-enabled interfaces at regular intervals.
dot1x reauthMax Sets the maximum number of times that a port attempts 802.1x reauthentication before the port changes to the unauthorized state.
