The Telemetry profile configuration
mode is not available until the telemetry profile
command is entered.
Parameters
profile-type
The type of MPLS profile for
the telemetry configuration. The available MPLS profile types are mpls-traffic-lsp, mpls-traffic-bypass, and mpls-traffic-fec.
telemetry-profile-name
The MPLS profile name. The
available MPLS profile names are default_mpls_traffic_lsp_statistics, default_mpls_traffic_bypass_statistics, and default_mpls_traffic_fec_statistics.
Modes
Global configuration mode
Usage Guidelines
The MPLS profile types are supported only on SLX 9540 and
SLX 9640 devices.
The "no" command is not supported for
default telemetry profiles. Only the default telemetry profiles are supported. These
profiles will contain all the streaming attributes supported. You can customize
these profiles by adding or removing attributes using the add or no add sub command or
by changing the interval using the interval sub command.
If a telemetry profile has no attributes, no information is streamed to the
collector. The MPLS profile can be used for streaming after:
Specifying the required MPLS LSP
names for the mpls-traffic-lsp type profile using the lsp sub
command.
Specifying the required MPLS Bypass
LSP names for the mpls-traffic-bypass type profile using the bypass-lsp sub
command.
Specifying the required MPLS LDP
FEC addresses for the mpls-traffic-fec type profile using the fec sub
command.
The statistics gathered by the MPLS
profiles are:
Out-packets
Out-bytes
Example of entering telemetry
profile configuration mode for an MPLS LSP configuration.
