Enables debugging for IP Protocol Independent Multicast.
Syntax
debug ip pim{add-del-oif|bootstrap|group|join-prune|nbr-change|packets|parent|regproc|route-change|rp|source|state|all}no debug ip pimall
Command Default
All flags are disabled.
Parameters
add-del-oif
Controls the OIF change flag.
bootstrap
Controls the bootstrap processing flag.
group
Controls the processing for a group flag.
join-prune
Controls the Join/Prune processing flag.
nbr-change
Controls the neighbor changes flag.
packets
Controls the packet processing flag.
parent
Controls the parent change processing flag.
regproc
Controls the register processing flag.
route-change
Controls the route changes flag.
rp
Controls the Rendezvous Point (RP) processing flag.
source
Controls the processing for a source flag.
state
Controls the state processing flag.
all
Controls all of the states.
Modes
Privileged EXEC mode
Usage Guidelines
Diagnostic commands are developed and intended
for specialized troubleshooting. Work closely with Extreme Networks technical
support when running debug or show
system internal commands and interpreting their results.
Use the
no debug ip pim all command to disable debugging.
