accept-lifetime Defines the time period when a key is active.
accept-tolerance Defines the number of seconds for which expired or soon-to-be activated keys can be used for validating received packets.
action (management-heartbeat) Specifies an action to be performed when the SLX device does not receive heartbeat messages from EFA within a preconfigured threshold time duration.
acl-log-raslog Enables Raslog messages for ACL rules with log keywords, and specifies how long the system waits before sending an ACL Raslog message.
acl-mirror Defines a destination for ACL-based mirroring of a physical interface. This command will be deprecated in the future.
acl-policy Accesses the ACL policy configuration mode, from which you can change the default settings regarding conflicting and duplicate ACL rules.
action event-stream Activates the event-stream action within the event-stream configuration mode.
action python-script Specifies a Python file that runs when a trigger condition occurs.
action-timeout For an implementation of an event-handler profile, specifies the maximum number of minutes to wait for an action-script to complete execution. If the action-timeout expires, then script execution ends.
activate (telemetry collector) Activates the telemetry data stream—as defined by the telemetry profiles—to the external telemetry collector.
adaptive Bypass LSPs can be made adaptive using the adaptive command. Bypass LSPs are non-adaptive by default. The user can modify the adaptive bypass LSPs adaptive-parameters without disabling the LSP. If the LSP is UP, then modifying an adaptive parameter, like exclude-interface or bandwidth, leads to the creation of a new instance of the bypass LSP. Adaptiveness can be manually enabled by using the adaptive command and can be disabled by no form of the same command. Use the adaptive to set the adaptive option for the dynamic bypass LSPs to be created for the MPLS protected interface.
add (telemetry) Restores a previously removed field to a telemetry profile.
additional-paths Enables an additional-paths capability for all peers in a Border Gateway Protocol (BGP) address family.
additional-paths select Configures routes that are eligible for selection as additional-paths by peers configured under a Border Gateway Protocol (BGP) address family.
address-family l2vpn evpn (BGP) Enables the L2VPN address family configuration mode to configure a variety of BGP EVPN options.
address-family unicast (BGP) Enables the IPv4 or IPv6 address family configuration mode to configure a variety of BGP unicast routing options.
address-family unicast (IS-IS) Enables the IPv4 or IPv6 address family configuration mode for configuring a variety of Intermediate System-to-Intermediate System (IS-IS) unicast routing options.
adjustment-interval There are two mechanisms of configuring LSP level parameters. The direct configuration and template-based configuration.
adjustment-threshold Specifies the automatic bandwidth adjustment sensitivity of an LSP to changes in bandwidth utilization.
admin-group Administrative groups, also known as resource classes or link colors, allows the user to assign MPLS-enabled interfaces to various classes. When a device calculates the path for an LSP, it can take into account the administrative group to which a interface belongs; the user can specify which administrative groups the device can include or exclude when making its calculation.
advertise dot1-tlv Advertises globally to any attached device IEEE 802.1 organizationally specific Type, Length, Values (TLV) values, or for a specific LLDP profile.
advertise dot3-tlv Advertises to any attached device IEEE 802.3 organizationally specific Type, Length, Values (TLV) values, or for a specific LLDP profile.
advertise optional-tlv Advertises the optional Type, Length, and Values (TLV) values, or for a specific LLDP profile.
advertise-backup Enables a backup VRRP router to send advertisement frames to the master VRRP router.
advertise-best-external Stores and advertises the best external route for a Border Gateway Protocol (BGP) address family.
advertisement-interval (VRRP) Configures the interval at which the master VRRP router advertises its existence to the backup routers.
advertisement-interval-scale Configures the sub-second intervals at which the master VRRP-Ev3 device advertises its existence to the backup routers.
agent-enable Enables the Keylime agent on the SLX device. This agent registers itself with remote keylime server(registrar) and listens for queries from the remote Keylime server(verifier).
agent-port Assigns the port on which the Keylime agent communicates.
agent-uuid Assigns a UUID value to the Keylime agent installed on the SLX device.
aggregate-address (BGP) Configures the device to aggregate routes from a range of networks into a single network prefix.
alias Configures global or user-level aliases for device commands.
alias-config Launches the alias configuration mode, enabling you to define aliases.
allow-conflicting-rules Towards editing ACLs, disables the default restriction on conflicting rules within an ACL. You can then create a conflicting rule before deleting the previous version.
allow-duplicate-rules Towards editing ACLs, disables the default restriction on duplicate rules within an ACL. You can then create a duplicate rule at a new sequence before deleting the previous version.
always-compare-med Configures the device always to compare the Multi-Exit Discriminators (MEDs), regardless of the autonomous system (AS) information in the paths.
always-propagate Enables the device to advertise BGP routes even though they are not installed in the RIB Manager.
arp Creates a static Address Resolution Protocol (ARP) entry.
arp access-list Creates an Address Resolution Protocol (ARP) access control list (ACL), which is one of the steps implementing Dynamic ARP Inspection (DAI) on a VLAN.
as-path-ignore Disables the comparison of the autonomous system (AS) path lengths of otherwise equal paths.
auth-check Disables Intermediate System-to-Intermediate System (IS-IS) authentication checking globally.
auth-key Configures an authentication key for Intermediate System-to-Intermediate System (IS-IS) globally.
auth-mode Specifies the type of authentication used in Intermediate System-to-Intermediate System (IS-IS) packets globally.
auth-port Configures a user datagram protocol (UDP) port for Remote Authentication Dial-In User Service (RADIUS) server authentication.
auto-shutdown-new-neighbors Disables the establishment of BGP connections with a remote peer when the peer is first configured.
autobw-threshold table Changes the parser mode to the config-router-mpls-autobw-threshold-table mode, allowing the user to change the absolute adjustment threshold values.
backup-advertisement-interval Configures the interval at which backup VRRP routers advertise their existence to the master router.
bandwidth-ceiling This command adds a new threshold change point to the autobw-threshold table. When the change point is already there, the threshold value updates to the new value.
banner Defines an incoming, login, or message of the day banner.
beacon enable Configures LED beacons at device or interface level.
bestpath prefix-validation disable This command disables the validation of prefixes that are received from BGP peers when calculating best path. The default behavior is to allow using all prefixes for best path calculation.
bestpath prefix-validation disallow-invalid This command prevents the use of invalid prefixes for calculating bestpaths. The default behavior is to allow invalid prefixes to be used in bestpath calculation.
bfd holdover-interval Sets the time interval for which Open Shortest Path First (OSPF), Intermediate System to Intermediate System (IS-IS), or Border Gateway Protocol (BGP) routes are withdrawn after a Bidirectional Forwarding Detection (BFD) session is declared down.
bfd interval Configures Bidirectional Forwarding Detection (BFD) session parameters on an interface.
bfd max-session-support Defines the maximum number of Bidirectional Forwarding Detection sessions that can be created.
bfd shutdown Disables Bidirectional Forwarding Detection (BFD) on an interface.
bgp-redistribute-internal Causes the device to allow the redistribution of IBGP routes from BGP into OSPF for non-default VRF instances.
bmc Enters the BMC configuration mode from where all BMC related commands are executed.
bmc factory reset Resets the BMC configuration to the factory default settings.
bpdu-drop-enable Enables dropping Layer 2 (L2) bridge protocol data units (BPDUs) on endpoints in L2 interfaces.
breakout mode Configures breakout mode for the supported connectors.
bridge-domain Creates a bridge domain, which represents a switching or inter-connection domain for a wide range of service end-point types.
bridge-domain (EVPN) Specifies a bridge domain (BD), or adds or removes a range VLANs from the BD, for an Ethernet Virtual Private Network (EVPN) instance.
bridge-priority Specifies the bridge priority for the common instance.
bsr-candidate Configures a bootstrap router (BSR) as a candidate to distribute rendezvous point (RP) information to the other PIM-SM (Sparse Mode) devices in a PIM-SM domain.
bypass-lsp Creates a bypass LSP by using the bypass-lsp command. Thereafter, in the bypass LSP context, you must specify at least one interface as an excluded or protected interface.
bypass-lsp (Telemetry) Indicates the MPLS Bypass-LSP to be used for the mpls-traffic-bypass profile.
