neighbor additional-paths Enables an additional-paths capability for a specific peer or peer group in a Border Gateway Protocol (BGP) address family.
neighbor additional-paths advertise Configures the additional-paths to advertise to a neighbor for a Border Gateway Protocol (BGP) address family.
neighbor additional-paths disable Disables the inheritance of an additional-paths capability (from the address family or peer group level) for a specific peer or peer group in a Border Gateway Protocol ( BGP) address family.
neighbor advertisement-interval Enables changes to the interval over which a specified neighbor or peer group holds route updates before forwarding them.
neighbor allowas-in Disables the AS_PATH check function for routes learned from a specified neighbor so that BGP does not reject routes that contain the recipient BGP speaker's AS number.
neighbor alternate-as Adds a range of alternate autonomous system numbers (ASNs) for BGP dynamic neighbors.
neighbor announce-rpki-state This command enables the SLX device to announce the RPKI state to its iBGP neighbors also to receive the RPKI state with prefixes from the configured neighbor. The state is announced to the iBGP neighbor through the extended community attribute. RPKI state is only announced to the iBGP neighbor when neighbor send-community is enabled using the extended, all, or both settings for the command.
neighbor as-override Replaces the autonomous system number (ASN) of the originating device with the ASN of the sending BGP device.
neighbor bfd Enables Bidirectional Forwarding Detection (BFD) sessions for specified Border Gateway Protocol (BGP) neighbors or peer groups.
neighbor capability as4 Enables or disables support for 4-byte autonomous system numbers (ASNs) at the neighbor or peer-group level.
neighbor default-originate Configures the device to send the default IPv4 route 0.0.0.0 or the default IPv6 route ::/0 to a neighbor or a peer-group. Route maps can also be applied to the default-originated routes.
neighbor ebgp-btsh Enables BGP time to live (TTL) security hack protection (BTSH) for eBGP.
neighbor ebgp-multihop Allows eBGP neighbors that are not on directly connected networks and sets an optional maximum hop count.
neighbor enable-peer-as-check Enables the outbound AS_PATH check function so that a BGP sender speaker does not send routes with an AS path that contains the ASN of the receiving speaker.
neighbor encapsulation Sets the encapsulation type for an IPv4 neighbor, an IPv6 neighbor, or a peer group.
neighbor enforce-first-as Ensures that a device requires the first ASN listed in the AS_SEQUENCE field of an AS path-update message from EBGP neighbors to be the ASN of the neighbor that sent the update.
neighbor filter-list Specifies a filter list to be applied to updates from or to the specified neighbor.
neighbor flowspec redirect Configures the Border Gateway Protocol flow specification (BGP flowspec) redirect nexthop holder and action type at neighbor or peer-group level.
neighbor flowspec validation Configures Border Gateway Protocol flow specification (BGP flowspec) route validation at neighbor or peer-group level.
neighbor prefix-list Filters outgoing and incoming route updates to or from a particular BGP neighbor according to the length of its IP address and mask.
neighbor remote-as Specifies the autonomous system (AS) in which a remote neighbor resides.
neighbor remove-private-as Configures a device to remove private autonomous system numbers (ASNs) from UPDATE messages that the device sends to a neighbor.
neighbor route-map Filters the outgoing and incoming route updates to or from a particular BGP neighbor according to a set of attributes defined in a route map.
neighbor rpki validation status disable This command disables the RPKI validation for the configured neighbor. The default behavior is to allow the RPKI validation for the prefixes received from its neighbor.
neighbor send-community Enables sending the community attribute in updates to the specified BGP neighbor.
neighbor shutdown Causes a device to shut down the session administratively with its BGP neighbor.
neighbor static-network-edge Overrides the default BGP4 behavior and advertises the network to a neighbor or peer group only when the corresponding route is installed as a forward route in the routing table.
neighbor timers Specifies how frequently a device sends KEEPALIVE messages to its BGP neighbors, as well as how long the device waits for KEEPALIVE or UPDATE messages before concluding that a neighbor is dead.
neighbor unsuppress-map Removes route suppression from BGP neighbor routes when those routes have been suppressed as a result of aggregation. All routes matching route-map rules are unsuppressed.
neighbor update-source Configures the BGP device to communicate with a neighbor through a specified interface.
neighbor weight Specifies a weight that the device will add to routes that are received from the specified BGP neighbor. BGP gives preference to routes with higher weights.
net Configures an Intermediate System-to-Intermediate System (IS-IS) network entity title (NET) for the routing process.
network Configures the device to advertise a BGP network.
next-hop-mpls Configures BGP shortcuts using next-hop MPLS to force BGP to use an MPLS tunnel as the preferred route to a destination network when an MPLS LSP tunnel is available.
next-hop-recursion (Policy Based Routing) Enables recursive next-hop lookups in route maps. Available for both IPv4 and IPv6 next hop entries in the PBR route maps.
no debug Disables the debug process for the selected module or all modules.
no-core-isolation By default, the core isolation feature is enabled. When all the core interfaces between the Leaf and Spine nodes go down, the ESI interface will be made down. If the core isolation feature is disabled using this command, the ESI interface will not be made down, and then all the core interfaces between the Leaf and the Spine nodes go down.
node Penalizes all links originating from the node IP address.
non-revertive-mode Sets non-revertive mode for Ethernet Ring Protection (ERP).
nonstop-routing (IS-IS) Enables nonstop routing (NSR) for Intermediate System-to-Intermediate System (IS-IS).
notification-timer Sets the length of the EOL notification timer for LDP-IGP synchronization.
ntp authenticate This command enables or disables the NTP authentication at global level. If the authentication is enabled, the NTP packets from servers, peers, clients not having MAC is dropped. Only those servers/peers configured with key authentication is considered for time synchronization. Client requests only with authentication is served, whose key-IDs match with one of the trusted key-IDs.
ntp authentication-key Creates an authentication key to associate with the NTP server, thereby enabling NTP authentication.
ntp disable Disables the NTP server/client mode. Disabling the NTP server/client mode does not remove the configuration.
ntp peer Configures the NTP peers and specifies the peers to synchronize the system clock. A maximum of 8 NTP peers can be configured.
ntp server Specifies or adds an NTP server IP address and optionally associates an authentication key to the server.
ntp trusted-key This command configures additional subset of trusted key-IDs which can be used for NTP and client authentication. The keys configured for server/peer is implicitly considered as part of trusted keys.
operational-state Enables or disables support for OpenConfig Telemetry Support for SLX.
password-policy (TPVM mode) Command to configure the password length and other password strength restrictions for the TPVM password. This command is available under TPVM configuration mode.
path A path is a list of router hops that specifies a route across an MPLS domain. Once the user creates a path, the user can create signaled LSPs that see the path.
pdu-rate Configures pdu-rate value, which is the number of OAMPDUs per second.
peer Configures a peer IP address in a bridge domain. A corresponding pseudowire (PW) interface is created when the peer IP address is configured.
peer (MCT) Configures the IP address for the MCT cluster peer.
peer-dampening Enables dampening of unstable BGP Peers globally for all neighbors (IPv4, IPv6 across all VRFs). Dampening can be enabled on all neighbors or on an individual neighbour/a peer-group. Dampening cannot be applied on dynamic peers.
peer-group ipv6prefix-over-ipv4peer Enables exchanging of IPv6 routes over IPv4 BGP peer sessions. This configuration applies only to BGP neighbors that are members of a peer-group.
peer-interface Configures the Ethernet interface or port-channel to reach the MCT cluster peer.
penalty Sets the penalty value for a CSPF fate-sharing group.
permit ip host Creates a rule in an Address Resolution Protocol (ARP) ACL that permits ARP messages from a host specified by both IP and MAC addresses.
ping Verifies network connectivity between a source and a destination on a TCP/IP network.
pki ocsp Configures OCSP (Online Certificate Status Protocol) on a VRF with a source interface.
police cir Configures the committed information rate, committed burst size, exceeded information rate, and the exceeded burst size for the class map.
policy-map Configures a policy map containing a class map so that you can apply policer and QoS attributes to a particular interface.
preempt-mode Enables or disables preempt mode for a VRRP or VRRP Extended (VRRP-E) router session.
prefix-independent-convergence Configures BGP Prefix-Independent Convergence (PIC), providing a BGP next-hop and additional paths to the routing information base manager (RIBM) and forwarding information base (FIB) if applicable.
prefix-independent-convergence-static This command reduces the convergence time for the static routes when a failover from the primary static nexthop to the backup static nexthop happens.
primary-path Configures an explicit path for the bypass LSP or dynamic bypass LSP.
priority Sets the priority of a physical router in a VRRP router group.
priority-group-table Defines the Priority Group ID (PGID) and the scheduling policy associated with it. Each PGID can be assigned one of 16 values. The valid values are [0-7] and [15.0-15.7]. The value range 0-7 indicate DWRR priority and the range 15.0-15.7 indicate Strict Priority values. This configuration and the priority-table configuration sets how traffic is handled when congestion occurs. For DWRR traffic, packets are dropped when PFC is not enabled for that flow.
priority-table Maps the Priority Group Table entries to priority groups.
process-restart Enables the process restart (PR) capability (for fault recovery) for BGP, IS-IS, MPLS, OSPFv2, and OSPFv3.
python Launches an interactive Python shell, with an option to launch a Python script.
qos cos Changes the interface default Class of Service (CoS) value.
qos cos-mutation Applies a user configured QoS CoS-to-CoS mutation map to an interface.
qos cos-mutation Applies a CoS Mutation map on a physical or a port channel interface. Use this command to apply the all-zero-map special CoS Mutation map.
qos cos-traffic-class Applies a Quality of Service (QoS) CoS-to-traffic class mutation map on an interface.
qos cpu slot Configures the Traffic Manager CPU port shaper rate (all towers) to the line card CPU.
qos dscp-cos Applies a user configured QoS DSCP-to-CoS mutation map to an interface.
qos dscp-mutation Applies a user configured QoS DSCP mutation map to an interface.
qos dscp-traffic-class Applies a user configured QoS DSCP-to-traffic- class mutation map to an interface.
qos-dscp-mode This command is configures the mode selection for a VxLan Tunnel. When selected, the mode selection takes effect only at the Egress VTEP.
qos flowcontrol Configures link-level flow control (IEEE 802.3x Flow Control) in the transmission and reception direction on an interface or enables priority flow control on a CoS of an SLX 9150 or SLX 9250 interface.
qos map dscp-cos Creates a QoS map where the ingress DSCP value is mapped to outgoing 802.1P values. This configures a DSCP-to-CoS map on the ingress interface.
qos map dscp-mutation Creates a DSCP mutation by mapping the incoming DSCP value of the ingress packet to outgoing DSCP values.
qos map dscp-traffic-class Creates a QoS map for performing DSCP-to-traffic class mapping. You use the qos traffic-class-dscp command to apply the map to an interface.
qos map traffic-class-cos A QoS traffic class-to-CoS mutation map can be configured to create a priority mapping table using a traffic-class-cos map. The traffic class-to-CoS map is then applied to an egress interface to effect the priority re-mapping.
qos port-speed-up Increases the egress throughput rate on a Traffic Manager port on 10G or 100G ports.
qos red-profile Configures a weighted random early detection (WRED) profile which includes the setting of the thresholds and drop probability by percentage. The command also enables or disable Explicit Congestion Notification (ECN) feature.
qos remark dscp Enables Remark DSCP for physical and Port Channel interfaces.
qos-ttl-mode Configures QoS support for MPLS policies and VXLAN Layer 2 gateways, Layer 3 gateways, and Layer 2 and Layer 3 gateway interconnections.
qos tx-queue scheduler strict-priority Configures the strict priority (SP) value for the egress queue traffic class scheduler and assigns a deficit weighted round robin (DWRR) weight.
