aggregate-address
(BGP)
Configures the device to aggregate routes from a range of networks into a single network prefix.
Syntax
aggregate-address
ip-addr
ip-mask
ipv6-addr
ipv6-mask
advertise-map
map-name
as-set
attribute-map
map-name
summary-only
suppress-map
map-name
no aggregate-address
ip-addr
ip-mask
ipv6-addr
ipv6-mask
advertise-map
map-name
as-set
attribute-map
map-name
summary-only
suppress-map
map-name
Command Default
The address aggregation feature is disabled. By default, the device advertises individual routes for all networks.
Parameters
ip-addr
IPv4 address.
ip-mask
IPv4 mask.
ipv6-addr
IPv6 address.
ipv6-mask
IPv6 mask.
advertise-map
Causes the device to advertise the more-specific routes in the specified route map.
map-name
Specifies a route map to be consulted. Range is from 1 through 63 ASCII characters.
as-set
Causes the device to aggregate AS-path information for all routes in the aggregate routes from a range of networks into a single network prefix.
attribute-map
Causes the device to set attributes for the aggregate routes according to the specified route map.
map-name
summary-only
Prevents the device from advertising more-specific routes contained within the aggregate route.
suppress-map
Prevents the more-specific routes contained in the specified route map from being advertised.
map-name
Modes
BGP address-family IPv4 unicast configuration mode
BGP address-family IPv6 unicast configuration mode
BGP address-family IPv4 unicast VRF configuration mode
BGP address-family IPv6 unicast VRF configuration mode
Usage Guidelines
Use the
no form of this command to restore the defaults.
The following example aggregates routes from a range of networks into a single network prefix under the IPv6 address family and advertises the paths for this route as AS_SET.
device# configure terminal
device(config)# router bgp
device(config-bgp-router)# address-family ipv6 unicast
device(config-bgp-ipv6u)# aggregate-address 2001:db8::/32 as-set
