Configures matching based on TCP or
UDP source or destination port for a route-map sequence number.
Syntax
match port{eq|gt|lt}port-num-1match portneqport-num-1[ … port-num-32]match portrangeport-num-1port-num-2no
match port{eq|gt|lt}port-num-1no match portneqport-num-1[ … port-num-32]no match portrangeport-num-1port-num-2
Command Default
Source port or destination port matching is not configured.
Parameters
eqport-num-1
Specifies that
matching occurs when the packet source port or destination port is equal to
the specified port number, which must be a valid UDP or TCP port number in
the range from 0 through 65535.
gtport-num-1
Specifies that matching
occurs when the packet source port or destination port is greater than the
specified port number, which must be a valid UDP or TCP port number in the
ltport-num-1
occurs when the packet source port or destination port is less than the
Specifies that
matching occurs when neither the packet source port nor packet destination port is equal
to all of the specified ports. Specified ports must be a valid UDP or TCP
port number in the range from 0 through 65535.
Specifies that
matching occurs when the packet source port or destination port is within
the specified range of port numbers, which must be valid UDP or TCP port
numbers in the range from 0 through 65535.
Modes
Route-map configuration mode
Usage Guidelines
When match protocol
and match port are
specified in the same stanza, the protocol specified by the match protocol command
must be either TCP or UDP.
Up to 128 match
port statements are
allowed per
route-map sequence number for the following options:
eq
range
Only one match port statement is
allowed per
lt
gt
neq
When multiple match
port configurations exist, matching occurs when traffic matches any
one of the configured ports.
Configuring the range option may create a lot of TCAM
entries (due to rule expansion).
The no form of the command disables the configuration.
The
following example shows how to configure matching based on port numbered 45 for
sequence number 4 in a route-map named rm; a match occurs when either the packet
source or destination port is in the range from 3 through 6000.
device# configure terminal
device(config)# route-map rm permit 4
device(config-route-map-rm/permit/4)# match port range 3 6000
The following example shows how to configure matching
based on port for sequence number 4 in a route-map named rm; a match occurs when
both the packet source port and packet destination port are not equal to 34 and
56 and 67.
device(config-route-map-rm/permit/4)# match port neq 34 56 67
