Applies rules specified in a MAC access control list (ACL) to traffic entering or exiting an interface.
Syntax
mac access-groupACLname{in|out}no mac access-groupACLname{in|out}
Parameters
ACLname
Specifies the name of the standard or extended MAC access list.
in
Applies the ACL to incoming switched and routed traffic.
out
Applies the ACL to outgoing routed and (is supported on the Extreme 8720, Extreme 8520, SLX 9250, and SLX 9150 devices only.) also to switched traffic.
Modes
Interface-subtype configuration mode
Usage Guidelines
You can apply a maximum of five ACLs to a user interface, as follows:
One ingress MAC ACL—if the interface is in switchport mode
One egress MAC ACL—if the interface is in switchport mode
One ingress IPv4 ACL
One egress IPv4 ACL
One ingress IPv6 ACL
On the Extreme 8720, Extreme 8520, SLX 9250, and SLX 9150 devices only, you can apply MAC ACLs to port-channels (LAGs) only ingress.
You can apply an ACL to multiple interfaces. And you can apply an ACL twice—ingress and egress—to a given user interface.
To remove an ACL from an interface, enter the
no form of this command.
The following example applies a MAC ACL to
filter inbound packets only, on a specified Ethernet interface.
device(config)# interface ethernet 0/1
device(conf-if-eth-0/1)# mac access-group macacl2 in
The following example removes a MAC ACL from a specified port-channel interface.
device(config)# interface port-channel 62
device(config-Port-channel-62)# no mac access-group macacl2 in
