Specifies the name of the event-handler
profile. Valid values can have from 1 through 32 characters. The first
character must be alphabetic.
action python-scriptfile-name
Specifies a Python file that runs when a trigger-condition occurs. Valid values range from 4 through 32 characters (including the
.py extension). The first character must be alphanumeric.
descriptiondescription-text
Specifies a string describing the
event-handler profile. The string can be 1 through 128 ASCII characters in
length. Do not use the ? character.
If you need to use ! or \, precede
each with \.
triggertrigger-id
Defines an event-handler trigger and specifies an ID number for the trigger. Valid values are 1 through 100, and must be unique per event-handler profile. When the trigger-condition occurs, a Python script is run.
raslograslog-id
Specifies a RASlog message ID as the trigger.
patternposix-ext-regex
Specifies a POSIX extended regular expression to search for a match within the specified RASlog message ID. For examples, refer to the "trigger" topic.
Modes
Global configuration mode
Event-handler configuration mode for an existing event handler. (There is no need to enter the
exit command to return to global configuration mode.)
Usage Guidelines
You can create multiple event-handler profiles.
You can optionally specify a description, a trigger, or the Python script with this command; or specify them later.
An
event-handler command creates or accesses an event-handler profile and can also define one of the following parameters:
Description
One trigger
The Python-script action that runs on any trigger
You can also define the above parameters—including one or more triggers—from event-handler configuration mode.
A Python event-handler script runs only if all of the following occur:
Using the
copy command, copy the Python file to the
flash:// location on the device.
Using the
event-handler command, create an event-handler profile.
Either using the
event-handler command or in configuration mode for that profile:
Using the
trigger command, create one or more triggers.
Using the
action command, specify the Python script that will be triggered.
Using the
event-handler activate command, activate an instance of the event handler.
The trigger event occurs.
If an event-handler profile is not activated, the
no form of this command deletes it.
The following example creates an event-handler profile and accesses its configuration mode.
