dscp (QoS)
Defines the DSCP-to-EXP values for an MPLS QoS DSCP-to-EXP mutation map.
Syntax
dscp dscp-value to exp exp-value
no dscp dscp-value
Command Default
The default DSCP-EXP value.
dscp-exp map    'default' (dscp= d1d2)
 d1     : d2 0  1  2  3  4  5  6  7  8  9
 0      :    0  0  0  0  0  0  0  0  1  1
 1      :    1  1  1  1  1  1  2  2  2  2
 2      :    2  2  2  2  3  3  3  3  3  3
 3      :    3  3  4  4  4  4  4  4  4  4
 4      :    5  5  5  5  5  5  5  5  6  6
 5      :    6  6  6  6  6  6  7  7  7  7
 6      :    7  7  7  7
Parameters
dscp-value
Specifies the DSCP value.
exp exp-value
Specifies the EXP value.
Modes
DSCP-EXP configuration mode
Usage Guidelines
After configuring the mutation mapping, you can apply the map globally.
Use the no form of the command to reset the DSCP value.
This command is supported on the Extreme 8820 and SLX 9740 devices only.
The following example defines the DSCP-to-EXP mutation map.
device# configure terminal
device(config)# qos-mpls map dscp-exp dscpExpMap
device(dscp-exp-dscpExpMap)# dscp 0 to exp 7
