Configures the Traffic Manager CPU port
shaper rate (all towers) to the line card CPU.
Syntax
qos cpu slotline-card-number{groupgroup_id{prio{priority|all}|shaper rate shaper_rateburstburst_size|wfq weightweight_value}qos cpu slotline-card-number{port shaper
rateshaper_rateburstburst_size}no qos cpu slotline-card-number{groupgroup_id{prio{priority|all}|shaper rate shaper_rateburstburst_size|wfq weightweight_value}no qos cpu slotline-card-number{port shaper
Command Default
The Traffic Manager CPU group or port shaper
rate is not set.
Parameters
line-card-number
The values are 0 on Pizzabox platforms, 1
through 4 on F4 platforms, and 1 through 8 on F8 platforms.
group
group_id
Configures a CPU group.
shaper rateshaper_rate
Configures the Traffic Manager CPU shaper
rate (all towers) to the line card CPU for CPU groups. The rate is in kilo
bits per second (Kbps) with a range from 0 through 100000.
priopriority
rate (all towers) to the line card CPU for individual priority VoQs in a CPU
group. The priority value ranges from 0 through 7.
burstburst_size
Configures the CPU burst size. The burst
size value ranges from 1 through 64 KB.
Configures the CPU group's weighted fair
queue value (all towers). The weight value ranges from 1 through 128.
port
Configures a CPU port.
Modes
Global configuration mode.
Usage Guidelines
The
no form of the command removes the QoS CPU shaper configuration.
This example sets the Traffic Manager CPU port
shaper on slot 1 to priority 5, with a rate of 4500 Kbps, and a burst size of
1KB.
device# configure terminal
device(config)# qos cpu slot 1 port shaper rate 4000 burst 1
shaper on slot 1 to 4000 Kbps with a burst size of 1KB.
This example sets the Traffic Manager CPU on
slot 1 group 1 priority to 5, with a rate of 4500 Kbps, and a burst size of 1KB.
device(config)# qos cpu slot 1 group 1 priority 5 shaper rate 4500 burst 1
