Enables or disables debugging for IGMP information.
Syntax
debug ip igmp{all|errors |
groupA.B.C.D|packet
| rx | tx | interfaceethernet|port-channeltunnel|vlanvlan_id|bridge-domainbd_id}no debug ip igmp
Parameters
all
Enables all debugs.
errors
Enables only error type debugs, such as
memory allocation failures.
groupA.B.C.D
Specifies the group address, as a subnet
number in dotted decimal format (for example, 10.0.0.1), as the allowable
range of addresses included in the multicast group.
packet
Enables debug for queries or reports per the
chosen option.
rx
Specifies only ingressing flow debugs to be
captured in traces.
tx
Specifies only egressing packet flows to be
captured in traces.
interface
Specifies the interface (ethernet, port-channel, tunnel) to be monitored.
vlan
Specifies the VLAN to be monitored.
bridge-domain
Specifies the bridge domain
to be monitored.
Modes
Privileged EXEC mode
Usage Guidelines
Diagnostic commands are developed and intended
for specialized troubleshooting. Work closely with Extreme Networks technical
support when running debug or show
system internal commands and interpreting their results.
When debugging is enabled, all of the IGMP
packets received and sent and IGMP-host related events are displayed.
