user-id Enters into the configuration mode for each BMC User ID. BMC has 10 pre-defined users with IDs in the range 1-10. Each user ID is configured independently and this command enters into each user ID's configuration mode.
update onie Command to download and install the ONIE, ONIE-GRUB, and DIAG images.
update-time Configures the interval at which BGP next-hop tables are modified. BGP next-hop tables should always have IGP (non-BGP) routes.
usb Enables or disables an attached USB device. The device is inaccessible until it is enabled.
usb dir Lists the contents of an attached USB device.
usb remove Removes a file from an attached USB device.
use-v2-checksum Enables the v2 checksum computation method for a VRRPv3 IPv4 session.
user (alias configuration) Launches the user-level alias configuration mode, in which you can manage user aliases.
vrf Creates a Virtual Routing and Forwarding (VRF) instance and enters VRF configuration mode.
vrf (epvn IRB) Specifies a Ve interface, and optionally sets the cluster gateway for the Ve interface in Ethernet Virtual Private Network (EVPN) IRB for the VRF instance.
