Destination IPv6 prefix in hexadecimal with 16-bit values between colons, as
specified in RFC 2373.
prefix-length
A decimal value specifying the length of the IPv6 address prefix.
next-hop-ipv6-address
IPv6 address of the next-hop gateway.
link-local-next-hop-ipv6-address
IPv6 address of the link-local next-hop gateway.
ethernetslot/port
Specifies the Ethernet slot and port.
port-channelnumber
Specifies a port-channel interface.
veve-id
Specifies the virtual Ethernet (VE) interface.
metric
Specifies a value that the Layer 3 switch uses to compare this route to
other static routes in the IPv6 static route table that have the same
destination. The metric applies only to routes that the Layer 3 switch has
already placed in the IPv6 static route table. Two or more routes to the
same destination with the same metric will load share (as in ECMP load
sharing). The range is from 1 through 16. The default is 1.
distancenumber
Specifies an administrative distance. The range is from 1 through 254. The
default is 1. This is a value that the Layer 3 switch uses to compare this
route with routes from other route sources that have the same destination.
By default, static routes take precedence over routes learned by routing
protocols. To choose a dynamic route over a static route, configure the
static route with a higher administrative distance than the dynamic route. A
distance of 255 is considered unreachable.
tag
Specifies a tag value for the route. The route tag can be used for route
redistribution to routing protocols by means of route maps (as in IPv4
static route redistribution).
tag-number
A number from 0 through 4294967295. The default is 0.
next-hop-recursion
Specifies that if the next hop for a static route is reachable, then that
route is added to the routing table.
namename-value
Specifies the name to be assigned to this IPv6 route. This field can be used
to assign a meaningful, human readable description to this route
configuration. Maximum length 127 characters.
Modes
Global configuration mode
VRF configuration mode
Usage Guidelines
Use the no form of the command with the same parameters to remove
the IPv6 static route.
The following example creates an IPv6 static route for a destination network with the prefix
2001:DB8::0/32 and a next-hop gateway with the global address
2001:DB8:0:ee44::1. It also assigns a name to it.
device# configure terminal
device(config)# ipv6 route 2001:DB8::0/32 2001:DB8:0:ee44::1 name route-sj-01
The following example configures non-recursive lookup in the default VRF.
device(config)# ipv6 route next-hop-recursion
The following example configures non-recursive lookup in a non-default VRF named
red.
