Creates a maintenance domain at a specified level and name and enters the maintenance domain mode specified in the command argument.
Syntax
domain-namenamelevellevel
no domain-namenamelevellevel
Command Default
There is no domain configured.
Parameters
name
Specifies the domain name.
levellevel
Sets the domain level.
Modes
CFM protocol configuration mode
Usage Guidelines
The
name parameter is case sensitive. The
level parameter sets the domain level in the range 0 - 7. When the domain already exists, the level argument is optional. Typically, the levels are:
Customer‘s Domain Levels: 5 - 7
Provider Domain Levels: 3 - 4
Operator Domain Levels: 0 – 2
The
no form of the command removes the specified domain from the CFM protocol configuration mode.
