Specifies the maximum transmission unit (MTU) for the PW profile. The range is from 64 through 15966.
mtu-enforce
Configures MTU enforcement check during PW signaling.
false
Enables the MTU enforcement check.
true
Disables the MTU enforcement check.
vc-mode
When a pseudowire profile is attached to a bridge domain, on which routing is enabled (by using the
router-interface command), you are not allowed to change the pseudowire profile
vc-mode configuration to
raw.
Configures the virtual connection (VC) mode for the profile:
raw
Specifies using raw mode. At VC label imposition, when a tagged packet is received on a tagged AC endpoint, the VLAN tag is removed before it is sent out on the wire. When an untagged packet is received on an untagged AC endpoint it is encapsulated as is and sent out on the wire.
raw-passthrough
Specifies using raw-passthrough mode which enables interoperation with third-party devices. When all endpoints are configured as tagged endpoints, raw passthrough mode behaves the same way as tagged mode. When all endpoints are configured as untagged endpoints, raw-passthrough mode behaves the same way as raw mode. Select the
raw-passthrough option, when all endpoints are configured as untagged endpoints (even when peer devices signal the PW VC mode as raw).
tag
Specifies using tag mode. At VC label imposition, when a tagged packet is received on a tagged AC endpoint, the packet is encapsulated as is and sent out on the wire. When an untagged packet is received on an untagged AC endpoint, a dummy tag is added and it is sent out on the wire.
Modes
Global configuration mode.
Usage Guidelines
You can configure up to 64 PW profiles.
The
no form of the command removes the PW profile configuration.
The following example shows how to create a PW profile named test specifying that the VC mode for the profile is raw-passthrough.
device# configure terminal
device(config)# pw-profile test vc-mode raw-passthrough
