Provides the ability to filter traps based on severity level on both the host and the SNMPv3 host. Only RASLog (swEvent) traps can be filtered based on severity level. The configured severity level marks the reporting threshold. All messages with the configured severity or higher are displayed. If the severity level of None is specified, all traps are filtered and no RASLog traps are received. The default severity level is none.
use-vrf vrf-name
Configures SNMP to use the specified VRF to communicate with the host. The default is mgmt-vrf.
Specifies whether to use a loopback, management, or VE interface as a source
address for notifications. For management, specifies the chassis or
management IP address.
Modes
Global configuration mode
Usage Guidelines
You can associate a global SNMPv3 host only
with global SNMPv3 users and the local SNMPv3 host only with local SNMPv3 users. You
cannot create a SNMPv3 host by associating with the local SNMPv3 users and vice
versa.
The no form of the command can be used to remove the following
entities: notifytype, engineID,
udp-port, severity-level, and
use-vrf.
The following example creates an entry for SNMPv3 trap IPv4 host 10.23.23.45 associated with SNMP user "snmpadmin1."
device(config)# snmp-server v3host 10.23.23.45 snmpadmin1 severity-level info
The following example creates an entry for SNMPv3 trap IPv6 host 1050:0:0:0:5:600:300c:326b associated with SNMP user "snmpadmin2." The trap host receives SNMPv3 traps from the configured device.
device(config)# snmp-server v3host 1050::5:600:300c:326b snmpadmin2 severity-level Info
The following example associates the default-vrf VRF for a trap host recipient.
device(config)# snmp-server v3host 10.24.61.10 public use-vrf default-vrf
The following example removes the SNMP v3
host.
device(config)# no snmp-server v3host 10.24.61.10 public
