Specifies the server IP address in IPv4 or IPv6 format.
hostname
Specifies the host name, a string from 1 through 253 characters.
-c
Specifies the encryption algorithm for the SSH session. This parameter is optional. Supported algorithms include the following:
aes128-cbc
AES 128-bits
aes192-cbc
AES 192-bits
aes256-cbc
AES 256-bits
-lusername
Login name for the remote server. This parameter is optional. If you specify a user name, you will be prompted for a password. If you do not specify a user name, the command assumes you are logging in as root and will prompt for the root password.
-m
Specifies the HMAC (Hash-based Message Authentication Code) message encryption algorithm. This parameter is optional; if no encryption algorithm is specified, the default (hmac-md5) is used. Supported algorithms include the following:
hmac-md5
MD5 128-bits. This is the default setting.
hmac-md5-96
MD5 96-bits
hmac-sha1
SHA1 160-bits
hmac-sha1-96
SHA1 96-bits
interface
Specifies an interface.
ethernetslot/port
Specifies an Ethernet interface slot and
port number. The only supported value is 0.
management
Specifies the management interface.
vevlan-id
Range is from 1 through 4090 if Virtual Fabrics is disabled, and from 1 through 8191 if Virtual Fabrics is enabled.
vrfvrf-name
Specifies a VRF instance. See the Usage Guidelines.
Modes
Privileged EXEC mode
Usage Guidelines
Use this command to establish an encrypted SSH connection from a switch to a remote networking device. This implementation is based on SSH v2.
To use the
ssh command on the management VRF, use the
vrf keyword and enter
mgmt-vrf manually.
The following features are not supported:
Displaying SSH sessions
Deleting stale SSH keys
To connect to a remote device using an SSH connection with default settings:
device# ssh 10.70.212.152
The authenticity of host '10.70.212.152 (10.70.212.152)' can't be established.
RSA key fingerprint is f0:2a:7e:48:60:cd:06:3d:f4:44:30:2a:ce:68:fe:1d.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '10.70.212.152' (RSA) to the list of known hosts.
Password:
To connect to a remote device using an SSH connection with the management VRF:
device# ssh 10.70.212.152 vrf mgmt-vrf
To connect to a remote device using an SSH connection with a login name:
