Extreme SLX-OS Command Reference, 20.7.1
Commands K - M
> match as-path
Extreme Networks, Inc. March 26, 2025
Preface
About This Document
What's New in This Document
Supported Hardware
Using the SLX-OS CLI
User accounts
Accessing the CLI
Command modes
Using the do command as a shortcut
Using the top command as a shortcut
Displaying CLI commands and command syntax
Completing CLI commands
Using the comment character !
CLI keyboard shortcuts
Using CLI command output modifiers
Unsupported input characters
Debug and system diagnostic commands
Command shortcuts (aliases)
Configuring global aliases
Configuring user-level aliases
Commands A - B
aaa accounting
aaa authentication
aaa authorization command
accept-lifetime
accept-tolerance
action (management-heartbeat)
acl-log-raslog
acl-mirror
acl-policy
action event-stream
action python-script
action-profile
action-timeout
activate (telemetry collector)
activate (telemetry server)
activate (VXLAN overlay gateway)
adaptive
add (telemetry)
additional-paths
additional-paths select
address-family ipv4 flowspec
address-family l2vpn evpn (BGP)
address-family unicast (BGP)
address-family unicast (IS-IS)
adjustment-interval
adjustment-threshold
admin-group
advertise capabilities ac-influenced-df-election
advertise dot1-tlv
advertise dot3-tlv
advertise optional-tlv
advertise-backup
advertise-best-external
advertisement-interval (VRRP)
advertisement-interval-scale
agent-enable
agent-port
agent-uuid
aggregate-address (BGP)
alias
alias-config
allow-conflicting-rules
allow-duplicate-rules
allow multiple-ep-per-port
always-compare-med
always-propagate
anycast-rp
area authentication (OSPFv3)
area nssa (OSPFv2)
area nssa (OSPFv3)
area prefix-list (OSPFv2)
area range (OSPFv2)
area range (OSPFv3)
area stub (OSPFv2)
area stub (OSPFv3)
area virtual-link (OSPFv2)
area virtual-link (OSPFv3)
area virtual-link authentication (OSPFv3)
arp
arp access-list
as-path-ignore
auth-check
auth-key
auth-mode
auth-port
auto-cost reference-bandwidth (OSPFv2)
auto-cost reference-bandwidth (OSPFv3)
auto-shutdown-new-neighbors
autobw-threshold table
backup-advertisement-interval
bandwidth-ceiling
banner
beacon enable
bestpath prefix-validation disable
bestpath prefix-validation disallow-invalid
bfd
bfd holdover-interval
bfd interval
bfd max-session-support
bfd shutdown
bgp-redistribute-internal
bmc
bmc factory reset
bpdu-drop-enable
breakout mode
bridge-domain
bridge-domain (EVPN)
bridge-priority
bsr-candidate
bypass-lsp
bypass-lsp (Telemetry)
Commands C - D
capability as4-enable
ccm-interval
cee-map
certutil import sshkey
certutil sshkey
certutil sshx509v3
cfm linktrace
cfm loopback
cfm y1731 domain
channel-group
chassis
cipherset
cisco-interoperability
class
class-map
clear arp
clear bfd neighbors
clear bgp evpn l2routes
clear bgp evpn local routes
clear bgp evpn neighbor
clear bgp evpn neighbor dynamic all
clear bgp evpn routes
clear bgp ip flowspec local
clear bgp ip flowspec neighbor
clear bgp ip flowspec routes
clear bgp ip neighbor ipv6
clear cfm y1731 client-signal-fail statistics
clear cfm y1731 statistics
clear cfm y1731 statistics delay-measurement
clear cfm y1731 statistics synthetic-loss-measurement
clear counters
clear counters access-list
clear counters access-list overlay type vxlan
clear counters storm-control
clear dot1x statistics
clear erp statistics
clear erp wtb-time
clear erp wtr-time
clear filter-change-update
clear ip arp inspection statistics
clear ip arp suppression-cache
clear ip arp suppression-statistics
clear ip bgp dampening
clear ip bgp flap-statistics
clear ip bgp local routes
clear ip bgp neighbor
clear ip bgp neighbor dynamic
clear ip bgp routes
clear ip bgp rpki server
clear ip bgp traffic
clear ip dhcp relay statistics
clear ip dhcp snooping binding
clear ip flowspec rules statistics
clear ip igmp groups
clear ip igmp statistics
clear ip multicast snooping mcache
clear ip pim mdt
clear ip ospf
clear ip route
clear ipv6 bgp dampening
clear ipv6 bgp flap-statistics
clear ipv6 bgp local routes
clear ipv6 bgp neighbor
clear ipv6 bgp neighbor dynamic
clear ipv6 bgp routes
clear ipv6 bgp traffic
clear ipv6 counters
clear ipv6 dhcp relay delegated-prefixes
clear ipv6 dhcp relay statistics
clear ipv6 mld groups
clear ipv6 mld snooping
clear ipv6 mld statistics
clear ipv6 multicast snooping mcache
clear ipv6 nd suppression-cache
clear ipv6 nd suppression-statistics
clear ipv6 neighbor
clear ipv6 ospf
clear ipv6 pim mcache
clear ipv6 pim rp-map
clear ipv6 pim traffic
clear ipv6 route
clear ipv6 vrrp statistics
clear isis all
clear isis counts
clear isis database
clear isis force-spf
clear isis force-v6spf
clear isis ipv6 spf-log
clear isis neighbor
clear isis route
clear isis spf-log
clear isis traffic
clear lacp
clear lacp counters
clear link-oam statistics
clear lldp neighbors
clear lldp statistics
clear logging raslog
clear loop-detection
clear loop-detection bridge-domain
clear mac-address-table
clear mpls auto-bandwidth-samples
clear mpls lsp
clear mpls statistics
clear mvrp statistics
clear overlay-gateway
clear policy-map-counters
clear qos flowcontrol statistics
clear spanning-tree counter
clear spanning-tree detected-protocols
clear statistics bridge-domain
clear statistics vlan
clear tm voq-stat ingress-device
clear tm voq-stat slot
clear tunnel statistics
clear udld statistics
clear vrrp statistics
CLI
client
client-interface
client-interface (Y1731)
client-interfaces-shutdown
client-pw
client-to-client-reflection
clock set
clock timezone
cluster
cluster-client auto
cluster-track
commit
compare-med-empty-aspath
compare-routerid
confederation identifier
confederation peers
configure terminal
config-drift-track
connector
control-word
console
copy
core-isolation-disable
core-isolation-track
cos (MPLS)
cos (Y1731)
convergence-time
crypto ca authenticate
crypto ca enroll
crypto ca import
crypto ca import-pkcs
crypto ca trustpoint
crypto cert expiry-level
crypto import
crypto key
csnp-interval
cspf-computation-mode
cspf-interface-constraint
cspf-group
cspf-group-computation
dampening
database-overflow-interval (OSPFv2)
database-overflow-interval (OSPFv3)
debug access-list-log buffer
debug arp packet buffer
debug dhcp packet buffer
debug dot1x packet
debug ip bgp
debug ip bgp neighbor
debug ip igmp
debug ip ospf shortcuts
debug ip pim
debug ipv6 bgp
debug ipv6 bgp neighbor
debug ipv6 dhcp pd
debug ipv6 mld
debug ipv6 ospf graceful-restart
debug ipv6 pim
debug lacp
debug lldp dump
debug lldp packet
debug spanning-tree
debug udld packet
default-information-originate (BGP)
default-information-originate (IS-IS)
default-information-originate (OSPFv2)
default-information-originate (OSPFv3)
default-ipv6-gateway
default-link-metric
default-local-preference
default-metric (BGP)
default-metric (IS-IS)
default-metric (OSPF)
default-passive-interface
delay
delay-link-event
delete
delete-packet
deploy
description (BD)
description (event-handler)
description (interfaces)
description (LLDP)
description (STP)
description (VRRP)
designated-forwarder-hold-time
destination
dhcp ztp cancel
dhcp ztp log
dir
disable-adjacency-check
disable-incremental-spf-opt
disable-inc-stct-spf-opt
disable-partial-spf-opt
disallow-oar-ac
discard-packet
discard-voq-packet
distance (BGP)
distance (IS-IS)
distance (OSPF)
distribute
distribute-list prefix-list (OSPFv3)
distribute-list route-map
domain-name
dot1ag-compliance
dot1x authentication
dot1x enable
dot1x filter-strict-security
dot1x max-req
dot1x port-control
dot1x quiet-period
dot1x reauthenticate
dot1x reauthentication
dot1x reauthMax
dot1x test eapol-capable
dot1x test timeout
dot1x timeout
dpod
dscp (QoS)
dscp (Tunnel)
dscp-ttl-mode
duplicate-mac-timer (EVPN default instance)
dynamic-bypass
Commands E - F
efa deploy
enable
enable (ERP)
enable (GRUB)
enable (maintenance mode)
enable-on-reboot (maintenance mode)
enable (management-heartbeat)
encryption-level
enable-all-interfaces
enforce-first-as
eol
erp
error-disable-timeout enable
error-disable-timeout interval
esi
esi (BGP EVPN Multi-homing)
ethernet-segment
event
event-handler
event-handler abort action
event-handler activate
evpn
exclude-any
exclude-interface
exp
export-vrf-leaked-routes
export-map
extend bridge-domain
extend vlan
external-lsdb-limit (OSPFv2)
external-lsdb-limit (OSPFv3)
facility-backup
fast-convergence
fast-external-fallover
fast-flood
fastboot
fast-wtr-time
fec mode
fec (telemetry)
filter-change-update-delay
filter-fec-in
filter-fec-out
firmware activate
firmware commit
firmware download
firmware download ftp
firmware download fullinstall
firmware download interactive
firmware download scp
firmware download sftp
firmware download tftp
firmware download usb
firmware peripheral-update cpld
firmware peripheral-update fpga
firmware recover
firmware restore
flex-cli show link-fault-signaling
flex-cli show local-fault interface
flex-cli show local-fault slot
flex-cli show remote-fault interface
flex-cli show remote-fault slot
flow-label
flowspec validation
force-switch
format RFC-5424
forward-delay
Commands G - J
gNMI Server Configuration
graceful-restart (BGP)
graceful-restart (LDP)
graceful-restart (OSPFv2)
graceful-restart (OSPFv3)
graceful-restart helper (OSPFv3)
graceful-restart helper-disable (IS-IS)
graceful-shutdown
grub
guard-time
handle-isis-neighbor-down
hardware
hardware media-database activate
hardware smt
hello (LLDP)
hello (MPLS RSVP)
hello (UDLD)
hello padding
hello-acknowledgements
hello-interval (LD)
hello-interval (LDP)
hello-interval (PIM)
hello-interval-link
hello-interval-target
hello-time
hello-timeout (LDP)
hello-timeout-link
hello-timeout-target
helper-only
hold-time
holdoff-time
hop-limit
host-table aging-mode conversational
host-table aging-time conversational
hostname disable
http server
implicit-commit
import l2vpn evpn reoriginate
import vpnv4 unicast reoriginate
import vpnv6 unicast reoriginate
import-map
inactivity-timer
include-all
include-any
ingress-tunnel-accounting
ingress-vlan-mapped-ve-counter
init-route-calc-delay
insight enable
insight mode
install-igp-cost
instance
interface ethernet
interface loopback
interface management
interface port-channel
interface (telemetry)
interface ve
interval
interval (telemetry)
ip access-group
ip access-list
ip address
ip address (site)
ip anycast-address
ip arp gratuitous none
ip arp inspection
ip arp inspection filter
ip arp inspection trust
ip arp learn-any
ip arp-aging-timeout
ip dhcp relay
ip dhcp relay address
ip dhcp relay gateway
ip dhcp snooping
ip dhcp snooping enable
ip dhcp snooping information option
ip dhcp snooping trust
ip directed-broadcast
ip dns
ip extcommunity-list
ip forward
ip global-subnet-broadcast-acl
ip icmp-fragment enable
ip icmp rate-limiting
ip icmp redirect
ip icmp unreachable
ip igmp immediate-leave
ip igmp last-member-query-interval
ip igmp query-interval
ip igmp query-max-response-time
ip igmp router-alert-check-disable
ip igmp snooping enable
ip igmp snooping fast-leave
ip igmp snooping last-member-query-interval
ip igmp snooping mrouter interface
ip igmp snooping querier enable
ip igmp snooping query-interval
ip igmp snooping query-max-response-time
ip igmp snooping static-group
ip igmp snooping version
ip igmp ssm-map
ip igmp static-group
ip igmp version
ip interface loopback (overlay gateway)
ip irdp
ip large-community-list extended
ip large-community-list standard
ip mtu
ip option
ip ospf active
ip ospf area
ip ospf auth-change-wait-time
ip ospf authentication-key
ip ospf bfd
ip ospf cost
ip ospf database-filter
ip ospf dead-interval
ip ospf hello-interval
ip ospf ldp-sync
ip ospf md5-authentication
ip ospf mtu-ignore
ip ospf network
ip ospf passive
ip ospf priority
ip ospf retransmit-interval
ip ospf transmit-delay
ip pim dr-priority
ip pim snooping enable
ip pim-sparse
ip pim ttl-threshold
ip port (telemetry)
ip policy route-map
ip prefix-list
ip proxy-arp
ip receive access-group
ip route
ip route next-hop-recursion
ip route static bfd
ip route static bfd holdover-interval
ip router-id
ip router isis
ip source-guard enable
ip subnet-broadcast-acl
ip subnet-rate-limit
ip vrrp-extended auth-type
ip
ipv6 access-group
ipv6 access-list
ipv6 address
ipv6 anycast-address
show ipv6 dhcp relay
ipv6 dhcp relay distance
ipv6 dhcp relay address
ipv6 dhcp relay maximum-delegated-prefixes
ipv6 dns
ipv6 icmpv6 redirect
ipv6 icmpv6 rate-limiting
ipv6 icmpv6 unreachable
ipv6 mld snooping enable
ipv6 mld snooping fast-leave
ipv6 mld snooping last-member-query-interval
ipv6 mld snooping mrouter interface
ipv6 mld snooping mrouter logical-interface
ipv6 mld snooping querier enable
ipv6 mld snooping query-interval
ipv6 mld snooping query-max-response-time
ipv6 mld snooping static-group
ipv6 mld snooping version
ipv6 mld ssm-map enable
ipv6 nd cache expire
ipv6 nd cache interface-limit
ipv6 option disable
ipv6 ospf active
ipv6 ospf area
ipv6 ospf authentication ipsec
ipv6 ospf authentication ipsec disable
ipv6 ospf authentication spi
ipv6 ospf bfd
ipv6 ospf cost
ipv6 ospf dead-interval
ipv6 ospf hello-interval
ipv6 ospf hello-jitter
ipv6 ospf instance
ipv6 ospf mtu-ignore
ipv6 ospf network
ipv6 ospf passive
ipv6 ospf priority
ipv6 ospf retransmit-interval
ipv6 ospf suppress-linklsa
ipv6 ospf transmit-delay
ipv6 pim dr-priority
ipv6 pim snooping enable
ipv6 pim ttl-threshold
ipv6 pim-sparse
ipv6 policy route-map
ipv6 prefix-list
ipv6 protocol vrrp
ipv6 protocol vrrp-extended
ipv6 receive access-group
ipv6 route
ipv6 route next-hop-recursion
ipv6 route null
ipv6 route next-hop-vrf
ipv6 route static bfd
ipv6 route static bfd holdover-interval
ipv6 router isis
ipv6 router ospf
ipv6 router pim
ipv6 prefix-list
ipv6 subnet-zero drop
ipv6 vrrp-extended auth-type
ipv6 vrrp-extended-group
ipv6 vrrp-group
ipv6 vrrp-suppress-interface-ra
is-type
isis auth-check
isis auth-key
isis auth-mode
isis bfd
isis circut-type
isis hello-interval
isis hello-multiplier
isis hello padding
isis ipv6 metric
isis ldp-sync
isis metric
isis passive
isis point-to-point
isis priority
isis reverse-metric
iterations
Commands K - M
ka-int-count
ka-interval
ka-timeout
key
key (keychain)
key-add-remove-interval
key-algorithm
key-rollover-interval
key-string
keychain
keypair
label-withdrawal-delay
lacp auto
lacp default-up
lacp port-priority
lacp system-id
lacp system-priority
lacp timeout
lacp-pdu-forward enable
lag hash
ldap-server host
ldap-server maprole
ldp
ldp-enable
ldp-params
ldp-sync
left-interface vlan
license add
license eula
line vty exec-timeout
link-error-disable
link-fault-signal
link-oam allow-loopback
link-oam enable
link-oam remote-failure
link-oam remote-loop-back
listen-limit
listen-range
lldp profile
load-balance hash
load-sharing
local-as
local-switching
log (OSPFv2)
log (OSPFv3)
log adjacency
log invalid-lsp-packets
log-dampening-debug
log-shell
logging auditlog class
logging raslog console
logging raslog console stop
logging syslog-facility local
logging syslog-server
logging syslog-server-host
logging utility
logical-interface
loopback phy
loop-detection
loop-detection shutdown-disable
loop-detection vlan
lsp
lsp (Telemetry)
lsp-gen-interval
lsp-interval
lsp-refresh-interval
lsr-id
lvtep broadcast-local-bias
ma-name
mac access-group
mac access-list extended
mac access-list standard
mac-address withdrawal
mac-address-table aging-time
mac-address-table mac-move
mac-address-table static
maid-format
maintenance-mode (Interface)
management-heartbeat manager (management-heartbeat)
management-security
manual-switch vlan
map bridge-domain (overlay gateway)
map cos to cos
map dscp
map vlan
map vni auto (VXLAN gateway)
master-vlan (STP)
match (route maps)
match access-group
match additional-paths advertise-set
match as-path
match bridge-domain
match community
match destination-port
match dscp
match extcommunity
match fragment-type
match ip
match ip address acl
match ip icmp-code
match ip icmp-type
match ipv6 address
match ipv6 address acl
match large-community
match packet-length
match port
match protocol
match rpki
match source-port
match tcp-flags
match vlan
max-age
max-bypasses
max-bypasses-per-mp
max-lsp-lifetime
max-mcache
max-metric router-lsa
max-metric router-lsa (OSPFv3)
max-neighbor-reconnect-time
max-neighbor-recovery-time
maxas-limit
maximum-paths (BGP)
maximum-paths (IS-IS)
maximum-paths (OSPF)
maximum-paths ebgp ibgp
measured-boot
measurement-interval
med-missing-as-worst
member (cluster)
member-bridge-domain
member-vlan (STP)
mep
message-interval
message-interval
metric
metric-style wide
metric-type
minimum-links
mip-policy
mode (LLDP)
mode gre ip
monitor session
mpls reoptimize
mpls-interface
mtu (interface)
mtu (PW)
mtu-enforce
multipath
multiplier (LLDP)
multiplier (UDLD)
multi-topology
mvrp applicant-mode
mvrp enable
mvrp registration-mode forbidden vlan
mvrp timer
Commands N - Q
name (ERP)
name-prefix
nbr-timeout
neighbor activate
neighbor accept-lldp-neighbors
neighbor additional-paths
neighbor additional-paths advertise
neighbor additional-paths disable
neighbor advertisement-interval
neighbor allowas-in
neighbor alternate-as
neighbor announce-rpki-state
neighbor as-override
neighbor bfd
neighbor capability as4
neighbor capability orf prefixlist
neighbor default-originate
neighbor description
neighbor ebgp-btsh
neighbor ebgp-multihop
neighbor enable-peer-as-check
neighbor encapsulation
neighbor enforce-first-as
neighbor filter-list
neighbor flowspec redirect
neighbor flowspec validation
neighbor graceful-restart
neighbor graceful-shutdown
neighbor local-as
neighbor maxas-limit in
neighbor maximum-prefix
neighbor next-hop-self
neighbor next-hop-unchanged
neighbor password
neighbor peer-dampening
neighbor peer-dampening (peer-group)
neighbor peer-group
neighbor peer-group-name alternate-as-range
neighbor prefix-list
neighbor remote-as
neighbor remove-private-as
neighbor route-map
neighbor route-reflector-client
neighbor rpki validation status disable
neighbor send-community
neighbor shutdown
neighbor soft-reconfiguration inbound
neighbor static-network-edge
neighbor timers
neighbor unsuppress-map
neighbor update-source
neighbor weight
net
network
next-hop-enable-default
next-hop-mpls
next-hop-recursion
next-hop-recursion (Policy Based Routing)
no debug
no-core-isolation
node
non-revertive-mode
nonstop-routing (IS-IS)
nonstop-routing (OSPF)
notification-timer
ntp authenticate
ntp authentication-key
ntp disable
ntp peer
ntp server
ntp trusted-key
operational-state
optimized replication
oscmd
overlay access-group
overlay access-list type vxlan extended
overlay access-list type vxlan standard
overlay-gateway
overlay-service-policy
overlay-transit
partial-spf-interval
password
password-attributes
password-attributes expiry-alert-level
password-encryption convert-enc-to-level-10
password-policy (TPVM mode)
path
pdu-rate
peer
peer (MCT)
peer-dampening
peer-group ipv6prefix-over-ipv4peer
peer-interface
peer-keepalive (optional)
penalty
permit ip host
ping
pki ocsp
police cir
policy-map
port-channel path-cost
preempt-mode
prefix-independent-convergence
prefix-independent-convergence-static
primary-path
priority
priority-group-table
priority-table
process-restart
profile (LLDP)
profile (telemetry)
profile counters
profile etcam
profile lag
profile qos
profile route
profile tcam
profile tcam cam-share
protocol
protocol cfm
protocol link-oam
protocol lldp
protocol loop-detection
protocol mvrp
protocol spanning-tree
protocol udld
protocol vrrp
prune-wait
pw-profile
pw-profile (bridge domain)
python
qos cos
qos cos-mutation
qos cos-mutation
qos cos-traffic-class
qos cpu slot
qos dscp-cos
qos dscp-mutation
qos dscp-traffic-class
qos-dscp-mode
qos flowcontrol
qos map cos-mutation
qos map cos-traffic-class
qos map dscp-cos
qos map dscp-mutation
qos map dscp-traffic-class
qos map traffic-class-cos
qos port-speed-up
qos random-detect traffic-class
qos red-profile
qos remark dscp
qos rx-queue cos-threshold
qos rx-queue multicast
qos rx-queue unicast traffic-class
qos service-policy
qos traffic-class
qos traffic-class-cos
qos trust dscp
qos-mpls map dscp-exp
qos-mpls map exp-dscp
qos-mpls map exp-traffic-class
qos-mpls map-apply dscp-exp
qos-mpls map-apply exp-dscp
qos-mpls map-apply exp-traffic-class
qos-ttl-mode
qos tx-queue scheduler strict-priority
Commands R - Sh
radius-server host
raps-default-mac
raps-mel
raslog-duration
rate-monitoring
rd (EVPN VLAN/BD)
rd auto (EVPN)
reconnect-time
record
record-route
recovery-time
redistribute
redundant-management enable
refresh-reduction
region
registrar-server
registrar-port
reliable-messaging
reload
reload-delay
reload-delay enable
remark
remote-mep
rename
reoptimize-timer
resequence access-list
reservable-bandwidth
resilient-hash
retain route-target all
retransmit-interval
retries
retry-limit
retry-time
reverse-metric
revert-timer
revertive global
revertive hold-time
revision
rfc1583-compatibility (OSPF)
rib-route-limit
right-interface vlan
rpl
rpl-owner
rpki priority
server ssh
server tcp
rmon alarm
rmon collection history
rmon collection stats
rmon event
role name
rollback apply checkpoint
rollback checkpoint
rollback enable
root access console
root enable
route-map (BGP)
route-precedence
route-target
route-target (EVPN)
route-target (EVPN VLAN/BD)
router bgp
router isis
router mpls
router ospf
router pim
router-interface
rp-address
rp-candidate
rpf ecmp rebalance
rpf-mode
rsvp
rsvp-flooding-threshold
rsvp-periodic-flooding-time
rule
rule-name
rx-label-silence-time
secure-port
sample-recording
scheduler
seq (rules in IPv4 extended ACLs)
seq (rules in IPv4 extended bACLs)
seq (rules in IPv4 standard ACLs)
seq (rules in IPv6 extended ACLs)
seq (rules in IPv6 standard ACLs)
seq (rules in IPv4 standard bACLs)
seq (rules in MAC extended ACLs)
seq (rules in MAC standard ACLs)
service password-encryption
service-policy (control plane)
service-policy (interface)
session
set extcommunity
set interface
set ip dscp
set ip interface null0
set ip mirror
set ip next-hop
set ipv6 interface null0
set ipv6 next-hop
set large-community
set large-community-list delete
set police cir
set sflow
set traffic-action continue
set-debug
set-overload-bit
sflow agent-address
sflow collector
sflow enable
sflow polling-interval (global version)
sflow sample-rate
sflow update-destination-mac
sflow update-dst-mac(global version)
sflow source-interface
Show A through Show I
show access-list
show access-list overlay transit
show access-list overlay type vxlan acl-name
show access-list-log buffer
show access-list-log buffer config
show arp
show arp access-list
show bfd
show bfd neighbors
show bfd neighbors application
show bfd neighbors dest-ip
show bfd neighbors details
show bfd neighbors interface
show bgp evpn ethernet-segment
show bgp evpn evid
show bgp evpn vni
show bgp evpn interface tunnel
show bgp evpn l2route
show bgp evpn l2route next-hop
show bgp evpn l2route unreachable
show bgp evpn l3vni
show bgp evpn neighbors
show bgp evpn neighbors advertised-routes
show bgp evpn neighbors routes
show bgp evpn routes
show bgp evpn routes best
show bgp evpn routes detail
show bgp evpn routes local
show bgp evpn routes next-hop
show bgp evpn routes no-best
show bgp evpn routes not-installed-best
show bgp evpn routes rd
show bgp evpn routes rd type
show bgp evpn routes type
show bgp evpn routes type igmp-join-sync
show bgp evpn routes type igmp-leave-sync
show bgp evpn routes unreachable
show bgp evpn summary
show bgp ip flowspec
show bgp ip flowspec neighbors
show bgp ip neighbor ipv6
show bgp ip summary ipv6
show ip/ipv6 bgp peer-dampened
show bmc config-history
show bmc interface management status
show bmc interface management ip
show bmc password-status
show bmc status
show bridge-domain
show capabilities
show cee maps default
show cert-util sshkey
show cfm
show cfm y1731 action-profile
show cfm y1731 client-signal-fail
show cfm y1731 delay-measurement
show cfm y1731 synthetic-loss-measurement
show cfm y1731 test-profile
show chassis
show cipherset
show cli
show clock
show cluster
show cluster track
show config-drift-track
show copy-support status
show core-isolation track
show crypto ca
show crypto key
show debug all
show debug arp packet
show debug dhcp packet
show debug dhcp packet buffer
show debug ip bgp all
show debug ip igmp
show debug ip ospf internal lsp-shortcuts
show debug ip ospf all
show debug ipv6 pim
show debug lacp
show debug lldp
show debug spanning-tree
show debug vrrp
show defaults threshold
show dot1x
show environment fan
show environment history
show environment power
show environment sensor
show environment temp
show erp
show erp statistics
show event-handler activations
show file
show firmware peripheral cpld
show firmware peripheral fpga
show firmwaredownloadhistory
show firmwaredownloadstatus
show grubversion
show hardware media-database
show hardware profile
show hardware smt
show history
show http server status
show hw route-info
show interface
show interface stats brief
show interface stats detail
show interface stats utilization-watermark
show interface status
show inventory
show ip arp inspection
show ip arp inspection interfaces
show ip arp suppression-cache
show ip arp suppression-statistics
show ip arp suppression-status
show ip bgp
show ip bgp attribute-entries
show ip bgp dampened-paths
show ip bgp filtered-routes
show ip bgp flap-statistics
show ip bgp neighbors
show ip bgp neighbors advertised-routes
show ip bgp neighbors flap-statistics
show ip bgp neighbors last-packet-with-error
show ip bgp neighbors received
show ip bgp neighbors received-routes
show ip bgp neighbors rib-out-routes
show ip bgp neighbors routes
show ip bgp neighbors routes-summary
show ip bgp peer-group
show ip bgp routes
show ip bgp routes community
show ip bgp routes large-community
show ip bgp routes large-community access-list
show ip bgp routes large-community reg-expression
show ip bgp rpki details
show ip bgp rpki server summary
show ip bgp rpki table
show ip bgp summary
show ip bgp vpnv4 routes large-community
show ip bgp vpnv4 routes large-community access-list
show ip bgp vpnv4 routes large-community reg-expression
show ip bgp vpnv6 routes large-community
show ip bgp vpnv6 routes large-community access-list
show ip bgp vpn6 routes large-community reg-expression
show ip dhcp relay address
show ip dhcp relay gateway
show ip dhcp relay statistics
show ip dhcp snooping
show ip flowspec rules
show ip igmp groups
show ip igmp interface
show ip igmp snooping
show ip igmp ssm-map
show ip igmp statistics bridge-domain
show ip igmp statistics interface
show ip igmp statistics vlan
show ip interface
show ip multicast snooping
show ip ospf
show ip ospf area
show ip ospf border-routers
show ip ospf config
show ip ospf database
show ip ospf filtered-lsa area
show ip ospf interface
show ip ospf lsp-shortcuts
show ip ospf neighbor
show ip ospf redistribute route
show ip ospf routes
show ip ospf summary
show ip ospf traffic
show ip ospf virtual link
show ip ospf virtual neighbor
show ip pim bsr
show ip pim interface
show ip pim mcache
show ip pim mdt
show ip pim neighbor
show ip pim rp-candidate
show ip pim rp-hash
show ip pim rp-map
show ip pim rp-set
show ip pim rpf
show ip pim traffic
show ip route
show ip source guard binding entries
show ip subnet-rate-limit stats
show ipv6 bgp
show ipv6 bgp attribute-entries
show ipv6 bgp dampened-paths
show ipv6 bgp filtered-routes
show ipv6 bgp flap-statistics
show ipv6 bgp neighbors
show ipv6 bgp neighbors advertised-routes
show ipv6 bgp neighbors flap-statistics
show ipv6 bgp neighbors last-packet-with-error
show ipv6 bgp neighbors received
show ipv6 bgp neighbors received-routes
show ipv6 bgp neighbors rib-out-routes
show ipv6 bgp neighbors routes
show ipv6 bgp neighbors routes-summary
show ipv6 bgp peer-group
show ipv6 bgp routes
show ipv6 bgp routes community
show ipv6 bgp routes large-community
show ipv6 bgp routes large-community access-list
show ipv6 bgp routes large-community reg-expression
show ipv6 bgp summary
show ipv6 counters interface
show ipv6 dhcp relay address interface
show ipv6 dhcp relay delegated-prefixes
show ipv6 dhcp relay prefix-delegation-information
show ipv6 dhcp relay statistics
show ipv6 interface
show ipv6 mld groups
show ipv6 mld snooping
show ipv6 mld snooping mrouter
show ipv6 mld statistics
show ipv6 multicast snooping
show ipv6 multicast snooping mcache
show ipv6 nd
show ipv6 nd suppression-cache
show ipv6 nd suppression-statistics
show ipv6 nd suppression-status
show ipv6 neighbor
show ipv6 ospf
show ipv6 ospf area
show ipv6 ospf database
show ipv6 ospf interface
show ipv6 ospf memory
show ipv6 ospf neighbor
show ipv6 ospf redistribute route
show ipv6 ospf routes
show ipv6 ospf spf
show ipv6 ospf summary
show ipv6 ospf virtual-links
show ipv6 ospf virtual-neighbor
show ipv6 pim anycast-rp
show ipv6 pim bsr
show ipv6 pim group
show ipv6 pim interface
show ipv6 pim mcache
show ipv6 pim neighbor
show ipv6 pim rp-candidate
show ipv6 pim rp-hash
show ipv6 pim rp-map
show ipv6 pim rp-set
show ipv6 pim rpf
show ipv6 pim settings
show ipv6 pim traffic
show ipv6 prefix-list
show ipv6 route
show ipv6 static route
show ipv6 vrrp
show isis
show isis config
show isis counts
show isis database
show isis hostname
show isis interface
show isis neighbors
show isis routes
show isis spf-log
show isis traffic
show selinux status
show system internal bgp evpn nhid
show mac-address-table
Show J through Show Z
show lacp
show license
show link-oam info
show link-oam info detail
show link-oam statistics
show link-oam statistics detail
show lldp
show lldp interface
show lldp neighbors
show lldp statistics
show loop-detection
show management-heartbeat manager
show media
show media interface
show media optical-monitoring interface
show media tunable-optic-sfpp
show monitor
show mpls autobw-template
show mpls autobw-threshold-table
show mpls bypass-lsp
show mpls dynamic-bypass interface
show mpls interface
show mpls ldp
show mpls lsp
show mpls policy
show mpls rsvp
show mpls rsvp interface
show mpls rsvp session
show mpls statistics
show mpls te database
show mvrp
show mvrp attributes
show mvrp interface
show mvrp statistics
show netconf
show netconf capabilities
show notification stream
show ntp status
show ntp status association detail
show ntp status associations
show overlay-gateway
show onieversion
show policy-map
show port-channel
show port-channel load-balance
show port port-channel ethernet
show port-security
show process cpu
show process info
show process memory
show qos cpu cfg
show qos cpu info
show qos flowcontrol interface
show qos interface all
show qos interface
show qos interface port-channel
show qos interface ve
show qos maps
show qos maps cos-mutation
show qos maps cos-traffic-class
show qos maps dscp-cos
show qos maps dscp-mutation
show qos maps dscp-traffic-class
show qos maps traffic-class-cos
show qos maps traffic-class-dscp
show qos-mpls maps dscp-exp
show qos-mpls maps exp-dscp
show qos-mpls maps exp-traffic-class
show qos tx-queue interface
show rmon
show rmon history
show remote-attestation
show rollback checkpoint
show rollback diff checkpoint
show rollback feature-status
show rollback log
show rollback patch checkpoint
show rollback status
show route-map
show run router mpls cspf-group
show running-config
show running-config aaa
show running-config aaa accounting
show running-config aaa authorization
show running-config aaa authorization command
show running-config access-list overlay type vxlan
show running-config arp
show running-config control-plan ip subnet-rate-limit
show running-config dpod
show running-config event-handler
show running-config ip access-list
show running-config ip receive
show running-config ipv6
show running-config ipv6 access-list
show running-config keychain
show running-config lag hash
show running-config ldap-server
show running-config mac access-list
show running-config password-attributes
show running-config radius-server
show running-config rmon
show running-config role
show running-config rule
show running-config sflow
show running-config ssh
show running-config ssh server
show running-config ssh server key-exchange
show running-config system-monitor
show running-config telemetry collector
show running-config telemetry profile
show running-config telemetry profile (MPLS)
show running-config telemetry profile (queue)
show running-config telemetry server
show running-config username
show sflow
show span path session
show spanning-tree
show ssh client status
show ssh server status
show startup-config
show statistics access-list
show statistics access-list overlay type vxlan
show statistics bridge-domain
show statistics vlan
show statistics vpn
show storm-control
show support
show system maintenance
show system maintenance rate-monitoring
show system monitor tm
show tech-support
show telemetry client-cert
show telemetry collector name
show telemetry collector summary
show telemetry server status
show telnet server status
show threshold monitor
show threshold monitor ecmp
show threshold monitor host
show threshold monitor nexthop
show threshold monitor route
show threshold monitor sfp
show tm voq-stat ingress-device all discards
show tm voq-stat ingress-device all egress-port ethernet
show tm voq-stat ingress-device all max-buffer-util
show tm voq-stat ingress-device all max-queue-depth
show tm voq-stat ingress-device ethernet
show tm voq-stat slot
show topology-group
show tpm
show tpvm
show tpvm config
show tpvm config password-policy
show tunnel
show udld
show udld interface
show udld statistics
show users
show version
show vlan brief
show vlan detail
show vrf
show vrrp
show ztp status
Commands Shu - Z
shortcuts ospf
shutdown
shutdown (link-oam)
shutdown (STP)
shutdown-time
shutdown (cluster)
shutdown (interface)
shutdown (LIF)
shutdown-time
shutdown-time
site
snmp trap link-status disable
snmp-server community
snmp-server contact
snmp-server context
snmp-server enable trap
snmp-server engineid local
snmp-server group
snmp-server host
snmp-server location
snmp-server mib community-map
snmp-server preserve-statistics disable
snmp-server sys-descr
snmp-server trap
snmp-server use-vrf
snmp-server user
snmp-server v3host
snmp-server view
soft-preemption
soft-preemption cleanup-timer
source
source (monitor session)
source-interface (LDAP)
source-interface (RADIUS)
spanning-tree autoedge
spanning-tree bpdu-mac
spanning-tree cost
spanning-tree edgeport
spanning-tree guard root
spanning-tree link-type
spanning-tree portfast
spanning-tree priority
spanning-tree restricted-role
spanning-tree restricted-tcn
spanning-tree shutdown
speed (Ethernet)
spf-interval
spt-threshold infinity
ssh
ssh client cipher
ssh client cipher non-cbc
ssh client key-exchange
ssh client mac
ssh server algorithm
ssh server certificate
ssh server cipher
ssh server key
ssh server mac
ssh server max-auth-tries
ssh server max-idle-timeout
ssh server max-login-timeout
ssh server rekey-interval
ssh server rekey-volume
ssh server use-vrf shutdown
ssl-profile
ssm-enable
start (CFM)
start (Y1731)
start-shell
static-network
statistics
statistics (bridge domain)
statistics (VLAN)
stop (CFM)
stop (Y1731)
storm-control ingress (global)
storm-control ingress (interface)
subnet
sub-ring
summary-address (IS-IS)
summary-address (OSPFv2)
summary-address (OSPFv3)
summary-prefix
support autoupload-param
suppress-arp
suppress-nd
switch-attributes
switchport
switchport access
switchport mode
switchport mode trunk-no-default-native
switchport port-security
switchport port-security mac-address
switchport port-security max
switchport port-security shutdown-time
switchport port-security sticky
switchport port-security violation
switchport trunk allowed
switchport trunk native-vlan-untagged
switchport trunk native-vlan-xtagged
switchport trunk tag native-vlan
sync-interval
sysmon fe-acces-check
sysmon link-crc-monitoring
sysmon sfm-walk
system maintenance
system maintenance turn-off
system-description
system-monitor tm
system-monitor-mail
system-monitoring power alert state removed action raslog
system power-cycle-db-shutdown
system-name
table-map
tacacs-server
tag-type
tdpa
telemetry collector
telemetry profile
telemetry server
telnet
telnet server
terminal
test-profile
threshold
threshold (ETH-DM)
threshold (ETH-SLM)
threshold-monitor
threshold-monitor acl
threshold-monitor Cpu
threshold-monitor memory
threshold-monitor bfd-sessions
threshold-monitor ecmp
threshold-monitor hardware-resources
threshold-monitor host
threshold-monitor lif
threshold-monitor mac-table
threshold-monitor nexthop
threshold-monitor route
threshold-monitor sfp
threshold-monitor vxlan-tunnel
threshold-timer (management-heartbeat)
tie-breaking
timeout (link-oam)
timeout (RADIUS)
timeout (Y1731)
timer
timers (BGP)
timers (OSPFv2)
timers (OSPFv3)
tls min-version
tlv-type
to
topology-group
tpvm
tpvm config dns
tpvm config hostname
tpvm config ldap
tpvm config ldap ca-cert
tpvm config ntp
tpvm config timezone
tpvm config trusted-peer
tpvm deploy
tpvm download
tpvm fileinfo
tpvm (mode)
ldap host
ldap ca-cert
ntp (tpvm mode)
tpvm dns
hostname (tpvm mode)
timezone (tpvm mode)
trusted-peer (tpvm mode)
auto-boot (tpvm mode)
disk (tpvm mode)
password (tpvm mode)
allow-pwless (tpvm mode)
interface management (tpvm mode)
interface insight (tpvm mode)
deploy (tpvm mode)
tpvm upgrade
tpvm snapshot
traceroute
track (VRRP)
traffic-engineering (LSP)
traffic-engineering (MPLS)
transit-session-accounting
transport
trigger
trigger-function
trigger-mode
trustpoint sign
ttl
tunable-optics
tunneled-arp-trap enable
tx-frame-count
tx-interval
tx-label-silence-timer
type
Commands U - Z
udld enable
underflow-limit
underlay-mdt-default-group
underlay-mdt-group
undeploy-force
unlock username
user-id
update onie
update-time
usb
usb dir
usb remove
use-v2-checksum
user (alias configuration)
username
username
vc-id
vc-mode
version (ERP)
virtual-ip
virtual-mac
vlan
vlan (EVPN)
vpn-statistics
vrf
vrf (epvn IRB)
vrf forwarding
vrf-lite-capability
vrrp-acceptmode-disable
vrrp-extended-group
vrrp-group
vtep-discovery
write erase
wtb-time
wtr-time
y1731
match as-path
Syntax
Command Default
Parameters
Modes
Usage Guidelines
