radius-server host Configures a RADIUS server to connect for external server authentication.
raps-default-mac Sets the default Ring Automatic Protection Switching (R-APS) destination MAC address for Ethernet Ring Protection (ERP).
raps-mel Configures a Ring Automatic Protection Switching (R-APS) Maintenance Entity Group Level (MEL) value for Ethernet Ring Protection (ERP).
raslog-duration Configures the interval between RASLog messages that are sent when a port is disabled by the loop detection (LD) protocol.
rate-monitoring Adds the interface to a tracked list of interfaces monitored for link utilization.
rd (EVPN VLAN/BD) Configures a Virtual Private Network (VPN) route distinguisher for a VLAN/bridge domain (BD) in an Ethernet VPN (EVPN) default instance.
rd auto (EVPN) Enables auto-generation of a route distinguisher (RD) for an Ethernet Virtual Private Network (EVPN) default instance.
reconnect-time Specifies the amount of time that a graceful restart (GR) neighbor must wait for the LDP session to be reestablished.
record The user can configure the record route option using the record command.
record-route Use the record-route command's enable or disable options to set the record route option for the dynamic bypass LSPs to be created for the MPLS protected interface.
recovery-time Specifies the amount of time that this device retains its MPLS forwarding state across LDP graceful restart (GR).
redistribute Configures the device to redistribute IPv4 and IPv6 routes from one routing domain to another.
refresh-reduction When the user enables either of the refresh reduction extensions on an interface, outgoing RSVP packets sent on that interface sets the refresh reduction capability bit in the common RSVP header to indicate that the device is capable of receiving and processing refresh reduction messages and related objects.
region Assigns a name to a Multiple Spanning Tree Protocol (MSTP) region.
registrar-server Configures the various settings for accessing the remote Keylime Remote Attestation server.
registrar-port Configures the port on which the Keylime Remote Attestation server is listening for incoming connections.
reliable-messaging When RSVP reliable messaging is enabled on an interface of the SLX-OSdevice, RSVP trigger messages sent out on that interface includes a message ID and a request for acknowledgment from the RSVP neighbor.
reoptimize-timer The user can set a timer to optimize a specific LSP path on a periodic basis.
resequence access-list Reassigns sequence numbers to entries of an existing MAC, IPv4, or IPv6 access list.
reservable-bandwidth The reservable-bandwidth command is configurable on an MPLS-enabled interface at any time. The configuration of the command takes effect immediately upon preemption of the LSP.
resilient-hash Resilient Hashing is a feature that ensures that there is minimal disruption in traffic flow when there is a disruption due to a link failure or a link addition. Resilient Hashing is supported for L3 traffic routed using BGP (support for both IPv4 and IPv6 traffic) and Static Routes. The resilient-hash is used to enable and disable this feature as well as configuring the maximum path value.
retain route-target all Configures a route reflector (RR) to accept all route targets (RTs).
retransmit-interval Sets the time the device waits before it retransmits Link State PDUs (LSPs).
retries Configures the number of retries allowed to establish a connection with the Remote Authentication Dial-In User Service (RADIUS) server.
retry-limit Configures a limit on the number of times the ingress LER tries to connect to the egress LER in a signaled LSP.
retry-time Configures the amount of time the ingress LER waits between connection attempts.
reverse-metric Configures the reverse metric value at the Intermediate System-to-Intermediate System (IS-IS) router level.
revert-timer The path selection revert timer provides an option to stabilize a path before traffic is switched to it. Without a configured path selection revert timer, the router switches between a primary and secondary path immediately after the current working path goes down.
revertive global The revertive mode global command can be executed only on LSPs with FRR and adaptive enabled.
revertive hold-time Specifies the time, in seconds, the LSP holds before attempting a new path on the FRR LSP.
revision Assigns a version number to the Multiple Spanning Tree Protocol (MSTP) configuration.
rib-route-limit Limits the maximum number of BGP Routing Information Base (RIB) routes that can be installed in the Routing Table Manager (RTM).
right-interface vlan Configures an Ethernet Ring Protection (ERP) right interface.
rpl Configures an Ethernet Ring Protection (ERP) Ring Protection Link (RPL).
rpl-owner Set an Ethernet Ring Protection (ERP) bridge as a Ring Protection Link (RPL) owner.
rpki priority This command sets the priority of a server configured in the Resource Public Key Infrastructure's (RPKI) RPKI to Router Protocol (RTR) library. This command sets the priority of the RPKI Server contained in it. A RPKI server in a priority with a lower value will be chosen over a server in priority with a higher value.
server ssh This command establishes a SSH connection to the configured cache server. Establishing this connection enables the validation of prefixes with the RPKI server. Only one (1) cache server can be configured under one priority. Attempting to configure another RPKI server will report an error. The RPKI server connection is attempted through the Management VRF. Use the no format of this command to remove the configured RPKI server from the priority.
server tcp This command establishes a TCP connection to the configured cache server. TCP connections are not secured by nature. Establishing this connection enables the validation of prefixes with the RPKI server. Only one (1) cache server can be configured under one priority. Attempting to configure another RPKI server will report an error. The RPKI server connection is attempted through the Management VRF. Use the no format of this command to remove the configured RPKI server from the priority.
root access console Restricts the root access to the device to the console only.
root enable Enables root access to the device following a firmware configuration.
route-map (BGP) Creates or modifies a route-map under Border Gateway Protocol (BGP).
route-precedence Defines the order (precedence) in which unicast routes are selected from the unicast routing table (uRTM) for Reverse Path Forwarding resolution.
route-target Configures route-target for distribution of routes between VPN routing tables.
route-target (EVPN) Enables auto-generation of the import and export route-target community attributes for an Ethernet Virtual Private Network (EVPN) default instance.
route-target (EVPN VLAN/BD) Enables auto-generation of the import and export route-target community attributes for a VLAN/bridge domain (BD) in an Ethernet Virtual Private Network (EVPN) default instance.
router isis Enables Intermediate System-to-Intermediate System (IS-IS) routing.
router mpls Enables MPLS and accesses MPLS configuration mode
router ospf Enables and configures the Open Shortest Path First version 2 (OSPFv2) routing protocol.
router pim Configures basic global protocol-independent multicast (PIM) Sparse parameters on a device within the PIM Sparse domain and enters PIM-router configuration mode.
router-interface Binds a router interface to a tunnel or bridge domain.
rp-address Configures a device interface as a static rendezvous point (RP) for IPv4 PIM.
rp-candidate Configures a device as a candidate rendezvous point (RP) for all multicast groups with the prefix 224.0.0.0/4 (IPv4), by default, or for a specified group range.
rpf ecmp rebalance Enables multicast ECMP (equal-cost multi-path) load sharing with dynamic rebalancing of traffic to multiple paths through a network.
rpf-mode Enables strict or loose unicast Reverse Path Forwarding (uRPF) mode on an interface.
rsvp Accesses MPLS RSVP configuration mode to configure RSVP-TE Hello.
rsvp-flooding-threshold The rsvp-flooding-threshold command can be executed multiple times for the same interface. The threshold values are added to the existing set of values for the interface.
rule Creates role-based access permissions (RBAC) associated with a role.
rule-name Enables adding a meaningful, human readable rule name to a route map definition.
rx-label-silence-time Defines the length of the receive label silence timer for LDP-IGP synchronization.
secure-port Configures the port on which the SLX-OS device will listen for incoming secure connections. Configure a port in the range 1024-49151.
sample-recording Configures the template to record the sample history.
scheduler Configures the strict priority queues on an interface for QoS egress scheduling.
seq (rules in IPv4 extended ACLs) Inserts filtering rules in IPv4 extended ACLs. Extended ACLs permit or deny traffic according to source addresses, as well as other parameters.
seq (rules in IPv4 standard ACLs) Inserts filtering rules in IPv4 standard ACLs. Standard ACLs permit or deny traffic according to source address only.
seq (rules in IPv6 standard ACLs) Inserts filtering rules in IPv6 standard ACLs. Standard ACLs permit or deny traffic according to source address only.
seq (rules in MAC standard ACLs) Inserts filtering rules in Layer 2 (MAC) standard ACLs. Standard ACLs permit or deny traffic according to source address only.
service password-encryption Enables a global password encryption policy that overrides username encryption settings.
service-policy (control plane) Binds a policy map as a service policy for receive ACL (RACL) IPv4 and IPv6 inbound traffic to the control plane.
session Configures an LDP session for the neighbor-based filtering of inbound or outbound FECs, You can also configure an authentication key for the LDP session.
set extcommunity Sets an extended BGP community attribute in a route-map instance.
set interface Specifies an egress interface for a route-map.
set ip dscp Configures a Differentiated Services Code Point (DSCP) value for a route-map rule.
set ip interface null0 Drops traffic when the null 0 statement becomes the active setting as determined by the route-hop selection process for IPv4 policy-based routing.
set ip mirror Configures an IPv4 mirroring destination for a Border Gateway Protocol flow specification (BGP flowspec) route-map rule.
set ip next-hop Sets the IPv4 address of the redirect next hop in a route-map instance.
set ipv6 interface null0 Drops traffic when the null 0 statement becomes the active setting as determined by the route-hop selection process for IPv6 policy-based routing.
set ipv6 next-hop Sets the IPv6 address of the next hop in a route-map instance.
set police cir Configures a comitted information rate (CIR) value for a Border Gateway Protocol flow specification (BGP flowspec) route-map rule.
set sflow Enables traffic sampling for a Border Gateway Protocol flow specification (BGP flowspec) route-map rule.
set traffic-action continue Sets traffic processing to continue (that is, to apply any subsequent traffic-filtering rules) after matching a route-map rule.
set-debug Enables debug configurations for Intermediate System-to-Intermediate System (IS-IS).
set-overload-bit Configures a device to signal other devices not to use it as an intermediate hop in their shortest path first (SPF) calculations if the resources of the intermediate system are overloaded and preventing the IS from properly performing Intermediate System-to-Intermediate System (IS-IS) routing.
sflow sample-rate For sFlow, sets the number of packets that are skipped before the next sample is taken.
sflow update-destination-mac Updates the destination MAC address in the sFlow samples collected for analysis. This information can then be used for making peering decisions and correcting peering decisions.
sflow update-dst-mac(global version) When enabled, the destination MAC address in sFlow sample is updated with the MAC address of the next hop through which the destination IP address is reachable.
sflow source-interface Specifies to pick the IPv4 or IPv6 address of either the Ethernet, Virtual Ethernet (ve), management, or loopback interface as the source of sFlow packets.
