encryption-level Configures the encryption level to use for communication with the Remote Authentication Dial-In User Service (RADIUS) server.
enable-all-interfaces Use the enable-all-interfaces command to enable dynamic bypass on all the MPLS interfaces. This command disables dynamic bypass on all interfaces where dynamic bypass is not disabled using the interface level commands. MPLS interface specific dynamic bypass configurations take precedence over this configuration.
enforce-first-as Enforces the use of the first autonomous system (AS) path for external BGP (eBGP) routes.
esi Sets the Ethernet Segment ID (ESI) value, which is used to uniquely identify the client for the MCT client, or configures an auto-generated ESI value for a port channel client interface running LACP.
esi (BGP EVPN Multi-homing) Ethernet Segment Identifier (ESI) is a 10-octet identifier value that denotes an Ethernet Segment. It is used to discover and group the various interfaces of a multi-homed client. This command is used to manually assign Ethernet Segment Identifier (ESI) value to the segment. The same local port-channel id should be used by the multi-homed leaf peers on links connected to the same host.
ethernet-segment When a host device connects to multiple leaf nodes in a fabric through its interfaces, the aggregation of these links is termed as an Ethernet Segment (ES). Each host is assigned an unique 10-octet Ethernet Segment Identifier (ESI) that identifies this aggregation of connected ports. The assigned ESI value is used to discover other leaf nodes within the same ESI. This command navigates into a new configuration mode within which all ES configuration must be done. ESI values are not assigned to single homed nodes.
event-handler Creates or accesses an event-handler profile, which can execute a Python script when a specified trigger occurs.
event-handler abort action Under Python event-management, aborts a specified event handler that is currently running.
event-handler activate Activates an event handler and accesses event-handler activation mode, from which you can enter advanced configuration commands. You can also append the advanced commands to event-handler activate.
evpn Creates an EVPN instance and enables EVPN instance configuration mode.
exclude-any Interfaces that are not part of these groups, as well as interfaces that are not part of any group, are eliminated from consideration.
exclude-interface Configures one or more exclude interfaces for the bypass LSP.
exp Defines the QoS MPLS EXP-to-DSCP or EXP-to-traffic class mutation mapping.
fast-flood Configures Intermediate System-to-Intermediate System (IS-IS) to flood Link State PDUs to other devices in the network before running SPF.
fastboot Reboots the device without a power-on self-test (POST).
fast-wtr-time Sets the Wait to Restore (WTR) time for Ethernet Ring Protection (ERP) from minutes to seconds.
fec mode Configures the various Forward Error Corrections (FEC) parameters for the interface.
fec (telemetry) Indicates the MPLS FEC address to be used for the mpls-traffic-fec profile.
filter-change-update-delay Configures the delay period before application of a change to a Border Gateway Protocol flow specification (BGP flowspec) route-map rule.
filter-fec-in Configures LDP inbound or outbound FEC filtering to filter inbound label bindings on a MPLS router.
filter-fec-out Configures LDP outbound FEC filtering to filter outbound label bindings on a MPLS router.
firmware activate Activates the firmware that was downloaded with firmware download noactivate command.
