Configures matching based on packet
length for a route-map sequence number.
Syntax
match packet-length{eq|gt|lt}value-1match packet-lengthneqvalue-1[ ... value-32]match packet-lengthrangevalue-1value-2no
match packet-length{eq|gt|lt}value-1no match packet-lengthneqvalue-1[ ... value-32]no match packet-lengthrangevalue-1value-2
Command Default
Matching based on packet length is not configured.
Parameters
eqvalue-1
Specifies that
matching occurs when the packet length (including the IP header but
excluding the Layer 2 header) is equal to the specified value.
gtvalue-1
Specifies that matching
occurs when the packet length (including the IP header but excluding the
Layer 2 header) is greater than the specified value.
ltvalue-1
Layer 2 header) is less than the specified value.
Specifies that
matching occurs when the traffic packet length (including the IP header but
excluding the Layer 2 header)is not equal to all of the specified values.
You can specify a maximum of 32 values.
rangevalue-1value-2
Layer 2 header) is within the range of specified values.
Modes
Route-map configuration mode
Usage Guidelines
Up to 128 match
packet-length statements are
allowed per
route-map sequence number for the following options:
eq
range
When multiple match packet-length statements of the same type
exist, matching occurs when traffic matches any one of the statements.
Only one match packet-length statement is
allowed per
lt
gt
neq
Configuring the range option may create a lot of TCAM
entries (due to rule expansion).
The no form of the command disables the configuration.
The
following example shows how to configure matching based on a packet length of
1500 for sequence number 4 in a route map named rm.
