passive
      Configures specified OSPF interface as
         passive. This option is disabled by default.A passive interface receives routing
            updates, but does not transmit them.
            - Access Points — AP410i/e, AP460i/e,
               AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562, AP7612, AP7632, AP7662, AP8432,
               AP8533
Syntax
         passive [<WORD>|all|vlan <1-4094>]
      Parameters
                     | <WORD> | Enables the OSPF passive mode on the interface specified by the
                        <WORD> parameter |
                     | all | Enables the OSPF passive mode on all the L3 interfaces |
                     | vlan <1-4094> | Enables the OSPF passive mode on the specified VLAN interface
                           <1-4094> –
                              Specify the VLAN interface ID from 1 - 4094. |
         nx9500-6C8809(config-profile default-ap8533-router-ospf)#passive vlan 1
         nx9500-6C8809(config-profile default-ap8533-router-ospf)#show context
 router ospf
  ospf enable
  network 1.2.3.0/24 area 4.5.6.7
  area 0.0.0.4
  auto-cost reference-bandwidth 1
  default-information originate metric 1 metric-type 2
  passive vlan1
  ip default-gateway priority 1
