permit (bgp-as-path-list)
      Creates and configures a permit as-path-list rule. The permit rule
        specifies a regular expression to match. This regular expression is matched against the BGP
        AS paths contained in routing updates. AS paths matching the provided string are filtered
        and a permit action is applied.
        - Service Platforms — NX9500, NX9600
    Syntax
      permit as-path <REG-EXP>
    Parameters
              | permit as-path <REG-EXP> |
              Configures a match criteria (regular expression).
                  - <REG-EXP> – Specify the regular expression to match (should not exceed 64
                    characters and should be unique to the AS path list rule)
                 Regular expressions are treated as a ‘ASCII string‘ and not as a sequence of
                  numbers. Create a regular expression which is ideally suited to filter the
                  required AS paths.
    Usage Guidelines
      The following table lists some of the characters used in forming regular
          expressions:
Table 1.
                | Character to use |
                Description |
                Indicates the start of a string |
                Indicates the end of a string |
                | _ (underscore) |
                Indicates a comma, left brace, right brace, start and
                  end of an input string, or a space. For example, “_ _”. |
      nx9500-6C8809(config-bgp-as-path-list-test)#permit as-path _200_
      nx9500-6C8809(config-bgp-as-path-list-test)#permit as-path _323_
      nx9500-6C8809(config-bgp-as-path-list-test)#show context
bgp as-path-list test
 deny as-path ^100$
