deny (bgp-as-path-list)
      Creates and configures a deny as-path-list rule. The deny rule specifies
        a regular expression to match. This regular expression, is matched against the BGP AS paths
        contained in routing updates. AS paths matching the provided string are filtered and a deny
        action is applied.
        - Service Platforms — NX9500, NX9600
    Syntax
      deny as-path <REG-EXP>
    Parameters
              | deny as-path <REG-EXP> |
              Configures a match criteria (regular expression).
                  - <REG-EXP> – Specify the regular expression to match (should not exceed 64
                    characters and should be unique to the AS path list rule)
                 Regular expressions are treated as a ‘ASCII string‘ and not as a sequence of
                  numbers. Create a regular expression ideally suited to filter the required AS
                  paths.
    Usage Guidelines
      The following table lists some of the characters used in forming regular expressions:
Table 1.
                | Character to use |
                Description |
                Indicates the start of a string |
                Indicates the end of a string |
                | _ (underscore) |
                Indicates a comma, left brace, right brace, start and end of an input string,
                  or a space. For example, “_ _”. |
      nx9500-6C8809(config-bgp-as-path-list-test)#deny as-path ^100$
      nx9500-6C8809(config-bgp-as-path-list-test)#show context
bgp as-path-list test
 deny as-path ^100$
