beacon
         interface-config-bluetooth-instance
         Configures the Bluetooth
            radio‘s beacon‘s emitted transmission pattern for Bluetooth radios
            functioning in the low energy beacon (le-beacon) mode. This option
            is applicable only if the Bluetooth radio‘s operational mode is set
            to le-beacon.
      Supported in the
            following platforms:
            - Access Points –
               AP510, AP505, AP7602, AP7612, AP7622, AP7632, AP7662, AP8432,
               AP8533
beacon [pattern|period|txpower]
      beacon pattern
         [eddystone-url1|eddystone-ulr2|ibeacon]
      beacon period <100-10000>Parameters
         beacon pattern [eddystone-url1|eddystone-ulr2|ibeacon]
                        eddystone-ulr2| ibeacon] | When the beacon mode is set to ‘le-beacon‘,
                        use this command to configure the Bluetooth radio‘s
                        beacon‘s emitted transmission pattern. Select one of the
                        following beacon patterns:
                           eddystone-url1 – Transmits an Eddystone-URL
                              beacon using URL 1. This is the default
                              setting.eddystone-url2 – Transmits an Eddystone-URL
                              beacon using URL 2An Eddystone-URL
                                 frame broadcasts a URL using a compressed
                                 encoding scheme to better fit within a limited
                                 advertisement packet. Once decoded, the URL can
                                 be used by a client for Internet access. If an
                                 Eddystone-URL beacon broadcasts https:anysite,
                                 clients receiving the packet can access that
                                 URL. If setting the transmission pattern as
                                 ‘eddystone-url1‘ or ‘eddystone-ulr2‘, use the
                                 ‘eddystone‘ keyword to configure Eddystone
                                 beacon payload parameters. For more
                                 information, see eddystone.ibeacon – Transmits an ibeacon beacon. iBeacon
                              was created by Apple for use in iPhone OS (iOS)
                              devices (beginning with iOS version 7.0). There
                              are three data fields Apple has made available to
                              iOS applications, a Universally Unique IDentifier
                              (UUID) for device identification, a Major value
                              for device class and a Minor value for more
                              refined information like product category. If
                              setting the transmission pattern as ‘ibeacon‘, use
                              the ‘ibeacon‘ keyword to configure ibeacon beacon
                              payload parameters. For more information, see
                                 ibeacon. For
                           more information on configuring the Bluetooth radio‘s
                           operational mode, see mode. |
                     | beacon period <100-10000> | Configures the Bluetooth radio‘s beacon
                        transmission period, in milliseconds, from 100 - 10000.
                        As the defined period increases, so does the CPU
                        processing time and the number of packets incrementally
                        transmitted (typically one per minute).
                           <100-10000> – Specify a value from 100 -
                              10000 milliseconds. The default value is 1000
                              milliseconds. |
         beacon txpower <-15-6>
                     | beacon txpower <-15-6> | Configures the Bluetooth radio‘s le-beacon transmit
                        power. This determines how far a beacon can transmit
                           data.
                           <-15-6> – Specify a value from -15 - -6
                              dBM. The default value is -10 dBm. |
         nx9500-6C8809(config-profile-default-ap8432-if-bluetooth1)#beacon pattern
eddystone-url2
nx9500-6C8809(config-profile-default-ap8432-if-bluetooth1)#beacon period 900
nx9500-6C8809(config-profile-default-ap8432-if-bluetooth1)#show context
 interface bluetooth1
  shutdown
  description AP8432-BLE-Radio1
  mode le-beacon
  beacon pattern eddystone-url2
  beacon period 900
