mode
      Supported in the
            following platforms:
            - Access Points –
               AP510, AP505, AP7602, AP7612, AP7622, AP7632, AP7662, AP8432,
               AP8533
mode
               [bt-sensor|le-beacon|le-sensor|tron-tracking]
      Parameters
mode [bt-sensor|le-beacon|le-sensor|tron-tracking]
                     | mode | Configures the Bluetooth radio's mode of operation.
                        The options are:
                           bt-sensor – Select this option to enable the radio as a bt-sensor.
                              Bt-sensors are Bluetooth classic sensors providing robust wireless
                              connections for legacy devices. Typically these connections are not
                              ideally suited for the newer BLE (Bluetooth low energy)
                              technology supported devices. This is the default setting.le-beacon – Select this option to provide Bluetooth support for newer
                              BLE technology supported devices. le-beacons are newer Bluetooth low
                              energy beacons ideal for applications requiring intermittent or
                              periodic transfers of small amounts of data. le-beacons are not
                              designed as replacements for classic beacon sensors. If selecting this
                              option, use the beacon keyword to
                              configure the Beacon transmission period and Beacon transmission
                              pattern.le-sensor – Select this
                              option to provide Bluetooth support for LE (low energy)
                              asset tracking. When enabled, it uses the AP‘s Bluetooth radio
                              to detect BLE ‘asset tags‘ within the managed network. This
                              information is reported to a back-end server (for example, the
                              ExtremeLocation server or a third-party locationing server).
                              tron-tracking – TRON is a proprietary FedEx
                                 feature. Select this option to enable TRON
                                 tracking. When enabled, it BLE-enabled, WiNG  APs detect ‘ID Nodes‘ within a
                                 managed network and report to a proprietary
                                 FedEx back-end server application. If selecting
                                 this option, configure the Bluetooth radio's
                                 initial configurations needed to enable TRON
                                 tracking and reporting. For more information,
                                 see tron . Note: Tron-tracking is only
                                    supported on AP8533 model access
                                    point. |
nx9500-6C8809(config-profile-default-ap8432-if-bluetooth1)#mode le-beacon
nx9500-6C8809(config-profile-default-ap8432-if-bluetooth1)#show context
 interface bluetooth1
  shutdown
  mode le-beacon
  beacon pattern ibeacon
  ibeacon calibration-rssi -70
  ibeacon major 1110
  ibeacon minor 2210
  ibeacon uuid f2468da65fa82e841134bc5b71e0893e
Related Commands
                     |  | Reverts this Bluetooth radio‘s mode of operation to le-beacon |
