Negates a command or resets settings to their default. When used in the config role policy mode, the no command removes or resets the role policy settings.
no [default-role|ldap-deadperiod|ldap-query|ldap-server <1-2>|ldap-timeout|user-role]
no [ldap-deadperiod|ldap-query|ldap-server <1-2>|ldap-timeout]
no default-role use [ip-access-list|ipv6-access-list|mac-access-list]
no default-role use [ip-access-list|ipv6-access-list|mac-access-list] [in|out] <IP/IPv6/MAC-ACCESS-LIST-NAME> precedence <1-100>
no user-role <ROLE-NAME>
no <PARAMETERS>
| no <PARAMETERS> | Negates a command or resets settings to their default. When used in the config role policy mode, the no command removes or resets the role policy settings. |
The following example shows the role policy ‘test‘ setting before the ‘no‘ commands are executed:
nx9500-6C8809(config-role-policy-test)#show context role-policy test default-role use ip-access-list in test precedence 1 ldap-query self ldap-timeout 1 ldap-deadperiod 100 ldap-server 1 host 192.168.13.7 bind-dn CN=Adminstrator,CN=Users,DC=TechPub,DC=com base-dn CN=Administrator,CN=Users,DC=com bind-password 0 superuser port 2 nx9500-6C8809(config-role-policy-test)#
nx9500-6C8809(config-role-policy-test)#no ldap-deadperiod
         nx9500-6C8809(config-role-policy-test)#no ldap-timeout
         nx9500-6C8809(config-role-policy-test)#no ldap-server 1
         The following example shows the role policy ‘test‘ setting after the ‘no‘ commands are executed:
nx9500-6C8809(config-role-policy-test)#show context role-policy test default-role use ip-access-list in test precedence 1 ldap-query self nx9500-6C8809(config-role-policy-test)#
