Negates a command or resets configured settings to their default. When used in the config role policy user-defined role mode, the no command removes or resets settings, such as AP location, authentication type, encryption type, captive portal, etc.
no [ap-location|assign|authentication-type|captive-portal|city|client-identity| company|country|department|emailid|employee-type|employeeid|encryption-type| group|memberOf|mu-mac|radius-user|ssid|state|title|use|user-defined]
no [ap-location|assign|authentication-type|city|client-identity|company|country| department|emailid|employee-type|employeeid|encryption-type|group|mu-mac|memberOf|ssid| radius-user|state|title|user-defined]
no captive-portal authentication-state
no use [application-policy|bonjour-gw-discovery-policy|ip-access-list| ipv6-access-list|mac-access-list|url-filter]
no use [ip-access-list|ipv6-access-list|mac-access-list] [in|out] <IP/IPv6/MAC-ACCESS-LIST-NAME> precedence <1-100>
no use [application-policy|bonjour-gw-discovery-policy|url-filter]
no <PARAMETERS>
| no <PARAMETERS> | Negates a command or resets configured settings to their default. When used in the config role policy user-defined role mode, the no command removes or resets settings, such as AP location, authentication type, encryption type, captive portal, etc. |
The no command negates any command associated with it. Wherever required, use the same parameters associated with the command getting negated.
The following example shows the Role Policy ‘test‘ User Role ‘testing‘ configuration before the ‘no‘ commands are executed:
nx9500-6C8809(config-role-policy-test-user-role-testing)#show context user-role testing precedence 10 authentication-type eq kerberos encryption-type eq wep128 ap-location contains office mu-mac 11-22-33-44-55-66 group contains testgroup captive-portal authentication-state pre-login city exact SanJose company exact ExampleCompany country exact America department exact TnV emailid exact testing@examplecompany.com employeeid contains TnVTest1 nx9500-6C8809(config-role-policy-test-user-role-testing)#
nx9500-6C8809(config-role-policy-test-user-role-testing)#no authentication-type
         nx9500-6C8809(config-role-policy-test-user-role-testing)#no encryption-type
         nx9500-6C8809(config-role-policy-test-user-role-testing)#no group
         nx9500-6C8809(config-role-policy-test-user-role-testing)#no mu-mac
         nx9500-6C8809(config-role-policy-test-user-role-testing)#no ap-location
         nx9500-6C8809(config-role-policy-test-user-role-testing)#no employeeid
         The following example shows the Role Policy ‘test‘ User Role ‘testing‘ configuration after the ‘no‘ commands are executed:
nx9500-6C8809(config-role-policy-test-user-role-testing)#show context user-role testing precedence 10 captive-portal authentication-state pre-login city exact SanJose company exact ExampleCompany country exact America department exact TnV emailid exact testing@examplecompany.com nx9500-6C8809(config-role-policy-test-user-role-testing)#
