ftp
         Enables File Transfer Protocol (FTP) on this management policy. FTP is the
            standard protocol for transferring files over a TCP/IP network. FTP requires
            administrators enter a valid username and password authenticated locally. FTP access is
            disabled by default.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         ftp {password|rootdir|username}
         ftp {password [1 <ENCRYPTED-PASSWORD>|<PASSWORD>]}
         ftp {rootdir <DIR>}
         ftp {username <USERNAME> password [1 <ENCRYPTED-PASSWORD>|<PASSWORD>] rootdir <DIR>}
      Parameters
                     | ftp password | Optional. Configures the FTP server password |
                     | 1 <ENCRYPTED- PASSWORD> | Configures an encrypted password. Use this option when copy pasting the
                        password from another device.
                           <ENCRYPTED-PASSWORD> – Specify the password. The password
                              should not exceed 63 characters in length. |
                     | <PASSWORD> | Configures a clear text password |
         ftp {rootdir <DIR>}
                     | ftp rootdir <DIR> | Optional. Configures the root directory for FTP logins
                           <DIR> – Specify
                              the root directory path. By default the root directory is set to
                              flash:/ |
                     | ftp username <USERNAME> | Optional. Configures a new user account on the FTP server. The FTP user
                        file lists users with FTP server access.
                           <USERNAME> –
                              Specify the username. The username should not exceed 32 characters in
                              length. |
                     | password [1 <ENCRYPTED-PASSWORD>|<PASSWORD>] | Configures an encrypted password
                           1
                              <ENCRYPTED-PASSWORD> – Specifies an encrypted password (use this
                              option if copy pasting from another device). The password should not
                              exceed 63 characters in length.<PASSWORD> -
                     | rootdir <DIR> | After specifying the password, configure the FTP root directory.
                           rootdir <DIR> –
                              Configures the root directory for FTP logins. Specify the root
                              directory path. |
      Usage Guidelines
         The string size of an encrypted password (option 1, password is
            encrypted with a SHA1 algorithm) must be exactly 40 characters. Copy paste the encrypted
            password here.
         nx9500-6C8809(config-management-policy-test)#ftp username superuser password test@123 rootdir dir
         nx9500-6C8809(config-management-policy-test)#show context
management-policy test
 http server
 ftp username superuser password 1 f617ca50c59fb47028f96db4baab5f3d8f03c03ab257960b0fd127c69f02cd7e rootdir dir
 no ssh
 aaa-login radius external
 aaa-login radius policy test
 banner motd "Have a Good Day"
      Related Commands
                     | no | Disables FTP and its settings, such as the server password, root
                        directory, and users |
