aggressiveness
      Configures a roaming aggressiveness value for wireless clients.
        Configuring this value increases the client‘s roaming capabilities in scenarios where the
        client‘s location is likely to change drastically and suddenly. For example, when a client
        hops on to a train that speeds up quickly. In such a scenario, the access point receives a
        maximum of 2 (two) messages, from the client, having relatively low RSSI value. This results
        in a decaying-average, which is above the specified handover-threshold value. Consequently,
        the client is unable to roam.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
      aggressiveness [highest|lowest|medium|medium-high|medium-low]
    Parameters
              | aggressiveness
                [highest|lowest|medium|medium-high|medium-low] | Configures a roaming aggressiveness value for wireless
                clients. The options are:
                  highest – De-authenticates client in case of any degradation in the client‘s
                    link quality. When selected, the access point considers only the RSSI value of
                    the last message received from the client.lowest – De-authenticates client only in case of significant degradation in
                    the client‘s link quality. When selected, the access point uses a weighted
                    average [80% of decaying average + 20% of last seen RSSI] as the final reported
                    RSSI value. This is the default setting.medium – This is an intermediate setting between not roaming and
                    performance.medium-high – Allows roaming even if performance goes down. When selected, the
                    access point calculates the client‘s signal strength based on average received
                    signal as well as last received signal level, weighted towards the last received
                    value.medium-low – Allows roaming even if performance goes average. When selected,
                    the access point calculates the client‘s signal strength based on average
                    received signal as well as last received signal level, weighted towards the
                    average value. |
      nx9500-6C8809(config-roaming-assist-policy-test)#aggressiveness medium-high
      nx9500-6C8809(config-roaming-assist-policy-test)#show context
roaming-assist-policy test
 action log
    Related Commands
              | no | Reverts the aggressiveness value to default
                (lowest) |
