Creates a DHCPv6 server policy and enters its configuration mode
DHCPv6 is a networking protocol for configuring IPv6 hosts with IP addresses, IP prefixes, or other configuration attributes required on an IPv6 network.
DHCPv6 servers pass IPv6 network addresses to IPv6 clients. The DHCPv6 address assignment feature manages non-duplicate addresses in the correct prefix based on the network where the host is connected. Assigned addresses can be from one or multiple pools. Additional options, such as the default domain and DNS name-server address, can be passed back to the client. Address pools can be assigned for use on a specific interface or on multiple interfaces, or the server can automatically find the appropriate pool.
When configured and applied to a device, the DHCPv6 server policy enables the device to function as a stateless DHCPv6 server.
dhcpv6-server-policy <DHCPv6-SERVER-POLICY-NAME>
| <DHCPv6-SERVER-POLICY-NAME> | Specify the DHCPv6 server policy name. If the policy does not exist, it is created. |
nx9500-6C8809(config)#dhcpv6-server-policy test nx9500-6C8809(config-dhcpv6-server-policy-test)#? DHCPv6 server policy Mode commands: dhcpv6-pool Configure DHCPV6 server address pool no Negate a command or set its defaults option Define DHCPv6 server option restrict-vendor-options Restrict vendor specific options to be sent in server reply server-preference Server preference value sent in the reply, by the server to client clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-dhcpv6-server-policy-test)#
| no | Removes an existing DHCPv6 server policy |
