To configure IPv6 routing settings:
RA Convert (milliseconds) |
Select this option to convert multicast router advertisements (RA) to unicast router advertisements at the dot11 layer. Unicast addresses identify a single network interface, whereas a multicast address is used by multiple hosts. This setting is disabled by default. |
Throttle |
Select this option to throttle RAs before converting to unicast. Once enabled, set the throttle interval and maximum number of RAs. This setting is disabled by default. |
Throttle Interval (milliseconds) |
Enable this setting to define the throttle interval (3 - 1,800 seconds). The default setting is 3 seconds. |
Max RAs |
Enable this setting to define the maximum number of router advertisements per router (1 - 256) during the throttle interval. The default setting is 1. |
Network Address |
Set the IPv6 network address. Other than the length and slightly different look versus an IPv4 address, the IPv6 address concept is same as IPv4. |
Gateway |
Set the IPv6 route gateway. A network gateway in IPv6 is the same as in IPv4. A gateway address designates how traffic is routed out of the current subnet. |
Interface |
If using a link local address, set the VLAN (1 - 4,094) used a virtual routing interface for the local address. |
Select Reset to revert to the last saved configuration.
