T5 CPE System
The T5 controller CPE System screen displays device hardware and SKU information for T5 controller managed CPE devices. Use this information to assess whether a controller is managing the correct CPE devices out of the total number of CPEs available.
To view CPE system information:
  1. Select the Statistics menu from the Web UI.
  2. Select the Wireless Controller node from the left navigation pane and select a T5 controller from amongst those displayed.
  3. Select and expand the CPE menu item to display its sub menu items.
  4. Select System.
    The CPE System screen displays the following:
    Device Lists the name of the T5 controller managed CPE device. Up to 24 CPEs can be managed by a single T5 controller.
    Product Type Displays the model (product) type of each T5 controller managed CPE.
    Serial Number Displays the hardware encoded serial number appended to each T5 controller managed CPE. The serial number is different from the MAC address and is not configurable in the user interface.
    SKU Lists each T5 managed CPE's SKU information to assess hardware product revision.
    Hardware Version Lists a hardware revision number for each listed CPE.
    MAC Lists each CPE's factory encoded MAC address used as the CPE's hardware identifier within the user interface.
  5. Select Refresh to update the screen's statistics counters to their latest values.
