A profile's advanced configuration is comprised its MINT protocol configuration, NAS identifier and port ID attributes. MINT provides secure profile communications at the transport layer. Using MINT, a device can be configured to only communicate with other authorized (MINT enabled) devices. Therefore, MINT is well designed for profile support, wherein a group of controller, service platform or access point managed devices share the same configuration attributes.
Refer to the advanced profile's Miscellaneous menu item to set the profile's NAS configuration. The profile database on the RADIUS server consists of user profiles for each connected NAS (network access server) port.
To set a profile's advanced configuration:
Go to Configuration → Profiles → Manage Profiles .
Select a target profile from those displayed on the screen.
Select Advanced and expand the menu item.
The following sub menu items are available as advanced profile configuration options:
