To add or edit profile's VPN settings:
Go to .
Select a target profile from those displayed on the screen.
Expand Security and select VPN..
Select Add to define a new IKe Policy configuration, Edit to modify an existing configuration or Delete to remove an existing configuration.
Name |
If creating a new IKE policy, assign it a 32 character maximum name to help differentiate this IKE configuration from others with similar parameters. |
DPD Keep Alive |
Configure the IKE keep alive message interval used for dead peer detection on the remote end of the IPSec VPN tunnel. Set this value in either Seconds (10 - 3,600), Minutes (1 - 60) or Hours (1). The default setting is 30 seconds. This setting is required for both IKEv1 and IKEV2. |
Mode |
If using IKEv1, use the pull-down menu to define the IKE mode as either Main or Aggressive. IPSEC has two modes in IKEv1 for key exchanges. Aggressive mode requires 3 messages be exchanged between the IPSEC peers to setup the SA, Main requires 6 messages. The default setting is Main. |
DPD Retries |
Use the spinner control to set the maximum number of keep alive messages sent before a VPN tunnel connection is defined as dead. The available range is from 1 - 100. The default setting is 5. |
IKE LifeTime |
Set the lifetime defining how long a connection (encryption/authentication keys) should last from successful key negotiation to expiration. Set this value in either Seconds (600 - 86,400), Minutes (10 - 1,440), Hours (1 - 24) or Days (1). This setting is required for both IKEv1 and IKEV2. |
Select + Add Row to define the network address of a target peer and its security settings.
Name |
If creating a new IKE policy, assign the target peer (tunnel destination) a 32 character maximum name to distinguish it from others with a similar configuration. |
DH Group |
Use the drop-down menu to define a Diffie-Hellman (DH) identifier used by the VPN peers to derive a shared secret password without having to transmit. DH groups determine the strength of the key used in key exchanges. The higher the group number, the stronger and more secure the key. Options include 2, 5 and 14. The default setting is 5. |
Encryption |
Select an encryption method used by the tunneled peers to securely interoperate. Options include 3DES, AES, AES-192, AES-256. The default setting is AES-256. |
Authentication |
Select an authentication hash algorithm used by the peers to exchange credential information. Options include SHA, SHA256 and MD5. The default setting is SHA. |
Select OK to save the changes made within the IKE Policy screen. Select Reset to revert to the last saved configuration. Select the Delete Row icon as needed to remove a peer configuration.
