T5 Fast Ethernet Utilization
T5 controllers can have their connected CPE fe ports (1-2) analyzed for performance analysis. A single T5 controller can manage up ton 24 CPE devices and 48 fe ports.
  • CPE- fe1-fe2
To view T5 controller connected CPE fe port utilization:
  1. Select the Statistics menu from the Web UI.
  2. Select the Wireless Controller node from the left navigation pane and select a T5 controller from amongst those displayed.
  3. Select the Interface menu item and expand it to display it sub menu items. Select Fast Ethernet. Select the Utilization tab.
    Review the following CPE fe Ethernet port utilization data:
    Name Displays the name of the selected CPE fe Ethernet port.
    Rx (Kpbs) Displays the listed CPE fe Ethernet port receive data rate (in Kbps).
    RX (p/s) Lists a packet per second Ethernet port receive rate.
    Rx Utilization (%) Lists each port's receive direction utilization as a percentage of available receive bandwidth available.
    Tx (Kbps) Displays the listed CPE ge Ethernet port transmit data rate (in Kbps).
    Tx (p/s) Lists a packet per second fe Ethernet port transmit rate.
    Tx Utilization (%) Lists each fe port's transmit direction utilization as a percentage of available transmit bandwidth available.
  4. Select Refresh to update the screen's statistics counters to their latest values.
