AP-8432 and AP-8533 model access points utilize a built-in Bluetooth chip for specific Bluetooth functional behaviors in a WiNG managed network. These platforms can use their Bluetooth-enabled radio to sense other Bluetooth-enabled devices and report device data (MAC address, RSSI and device calls) to an ADSP server for intrusion detection. If the device presence varies in an unexpected manner, ADSP raises an alarm.
AP-8432 and AP-8533 model access points emit either iBeacon or Eddystone-URL beacons. The AP‘s Bluetooth radio periodically sends non-connectable, undirected LE (low-energy) advertisement packets. These advertisement packets are short, and sent on Bluetooth advertising channels that conform to established iBeacon and Eddystone-URL standards. However, portions of the advertising packet are still customizable.
The System node expands to display the RF Domains created within the managed network.
The RF Domain statistics menu displays in the right-hand side of the screen, with the Health tab selected by default.
| Name | Lists the administrator assigned name of the access point‘s Bluetooth radio. |
| Alias | If an alias has been defined for the AP it is listed here. The alias value is expressed in the form of <hostname>: B<Bluetooth_radio_number>. If the administrator has defined a hostname for the AP, it is used in place of the AP‘s default hostname. |
| Radio State | Displays the current operational state (On/Off) of the Bluetooth radio. |
| Off Reason | If the Bluetooth radio is offline, this field states the reason. |
| Radio MAC | Lists the Bluetooth radio‘s factory-encoded MAC address serving as this device‘s hardware identifier on the network. |
| Hostname | Lists the AP's hostname as its network identifier. |
| Device MAC | Lists the AP‘s factory-encoded MAC address serving as this device‘s hardware identifier on the network. |
| AP Location | Lists the AP‘s administrator-assigned deployment location. |
| Radio Mode | Lists an access point‘s Bluetooth radio functional mode as either btsensor or le-beacon. |
| Beacon Period | Lists the Bluetooth radio‘s beacon transmission period from 100 -10,000 milliseconds. |
| Beacon Type | Lists the type of beacon currently configured. |
| Last Error | Lists descriptive text on any error that is preventing the Bluetooth radio from operating. |
