To add a new Management Access policy, or edit an existing configuration:
| Creating an Administrator Configuration | Use the Administrators tab to create specific users, assign them permissions to specific protocols and set specific administrative roles for the network. |
| Setting an Allowed Location Configuration | Use the Allowed Locations tab as means to control a user's access to locations (RF Domains/sites/tree-node paths) within your managed network. Use this option to configure an allowed-locations tag and associate one or more locations with the tag. |
| Setting the Access Control Configuration | Use the Access Control tab to enable/disable specific protocols and interfaces. Again, this kind of access control is not meant to function as an ACL, but rather as a means to enable/disable specific protocols (HTTP, HTTPS, Telnet etc.) for each Management Access policy. |
| Setting the Authentication Configuration | Refer to the Authentication tab to set the authentication scheme used to validate user credentials with this policy. |
| Setting the SNMP Configuration | Refer to the SNMP tab to enable SNMPv2, SNMPv3 or both and define specific community strings for this policy. |
| Setting SNMP Trap Configuration | Use the SNMP Traps tab to enable trap generation for the policy and define trap receiver configurations. |
| Setting T5 PowerBroadband SNMP | Use the T5 PowerBroadband tab set a unique SNMP configuration for T5 controller models. |
