Sensor Server
Sensor servers allow the monitor and download of device authorization data from multiple sensors and remote locations using Ethernet, TCP/IP or serial connections. Repeaters are available to extend the transmission range and combine sensors with various frequencies on the same receiver, thus extending the Advanced WIPS supported reporting range.
To view the Sensor Server statistics:
  1. Select the Statistics → System menu from the Web UI.
  2. Expand RF Domain and select Wireless Controller.
  3. Select Sensor Servers from the left-hand side of the UI.
    The Sensor Servers screen displays.
  4. Review the following configuration details:
    IP Address
    Displays a list of sensor server IP addresses. These are sensor resources available to the controller or service platform.
    Port
    Displays the port on which this server is listening.
    Status
    Displays whether the server is currently connected or not connected.
  5. Select Refresh to update the screen's statistics counters to their latest values
