T5 Interface Ethernet Counter
A T5 controller can have its Ethernet ports reviewed for transmit and receive packet throughput.
T5 controllers have the following Ethernet port designations:
  • T5- ge1-ge2
To view T5 controller Ethernet port counter statistics:
  1. Select the Statistics menu from the Web UI.
  2. Select the Wireless Controller node from the left navigation pane and select a T5 controller from amongst those displayed.
  3. Select Interface from the left-hand side of the UI.
  4. Select Ethernet Ports. The Counter tab displays by default.
    Review the following T5 controller Ethernet port counter data:
    Name Displays the name of the selected T5 controller's ge Ethernet port.
    Rx Octets Displays the number of octets (bytes) received by the listed T5 controller Ethernet port.
    Rx Packets Lists the number of data packets received for the listed T5 Ethernet port since this screen was last refreshed.
    Rx Pause Packets Lists the number of Ethernet flow control (Layer 2) packets received on this port since this screen was last refreshed.
    Tx Octets Displays the number of octets (bytes) transmitted by the listed T5 controller Ethernet port.
    Tx Packets Lists the number of data packets transmitted from the listed T5 Ethernet port since this screen was last refreshed.
    Tx Pause Packets Lists the number of Ethernet flow control (Layer 2) packets transmitted on this port since this screen was last refreshed.
  5. Select Refresh to update the screen's statistics counters to their latest values.
